Attached is pic of heat pump air handling unit with refridgerant lines entering the attic and assumption is they loop just inside the attic. I thinking there must be another tray inside the attic or at the top of the exterior concrete block wall which has a condensation drain line exiting the building per other attached pic. Am I correct??
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
In this business don't assume anything I can not tell much by your Pic's where is the condensing unit located in relation to the furnace A-coil. Refrigerant lines should not loop not sure what you are describing. Where is the A-coil and the electrical furnace located garage, interior home, attic you are not providing me enough info to help you
If the air handler is not in the attic, there would be no need for a "tray" in the attic. Did you enter the attic?
OBSERVATION > The picture posted is the air handler with the tray just below. Line going up through the drywall is one of the refrigerant lines out to the condenser located outside. The condensate line on the exterior has a leak at the 90 by the stucco.
hope this helps! Serving: Grand Rapids, West Michigan Sarasota south to Port Charlotte www.Aim-Homeinspection.com GrandRapis-HomeInspection.com 616-735-0703 c941-306-7667 CPI / Cert. 09111306 Inter-Nachi Licensed HI66 / Insured |
The A coil is inside the shown air handling unit which is located at the ceiling level of the garage. As shown in the pic there is a tray under the unit and no drainage line attached to the tray. The line you see is coming out of the exterior wall but no evidense as to where this line is going. I was in the attic but it was to diffulcult to reach this area.
I would say yes
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
What are you saying yes to I have not really found out what the questions were
My take on the question is that the pipes that you see outside (pic# 2) are connected to the pipe that runs under the pan in the 1st pic.
There is no reason for a pan in the attic. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I think Dave got it right. The line running under the unit is likly a condensation drain line with black insulation and going into the garage/house wall and running to the exterior wall.
| Waste Drain Line | Stephen Milka | Plumbing Inspections | 0 | 10/21/11 12:21 AM |
| Trapped dishwasher drain line OK? | kshepard | Plumbing Inspections | 17 | 11/19/09 9:44 AM |
| Capped drain line vent | rdawes | Inspecting HVAC Systems | 3 | 4/21/07 7:00 PM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 11:27 AM |
