Got a question about the vent off the condensation "T" while running the Central Air. How much air should be coming out of this?
Got a friend that says his blows quite of bit? New house. Thanks Andy B |
Thats probably not a vent on the condensate drain line, and there shouldn't be much air coming out. Should be a tee after a trap (as long as it's not tied into a stack vent ... which shouldn't be done anyway) with a short open vert pipe that comes up above the primary drain pan level as a cleanout. They may have put the cleanout tee before the trap without a loose cap, or not enough condensate is being generated to seal the air flow.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
It is the small 1/2 pvc line that comes out the furnace, tees up and down. Down to drain the condensate and up to vent.
So what you are saying is it doesn't condensate enough? How do you get it to condensate more? Burner/gas setting? Thanks! |
I will try and get a pic.
Robert is most likely correct, a picture would help
Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are all the vents open?
I agree with Bob. |
A pic would be helpful. And are you talking about the condensate drain line for a central air conditioner (my initial reaction) or a high efficiency forced air furnace?
In any event condensate is usually piped to daylight or a plumbing fixture tailpiece (before the fixture trap so sewer gas doesn't come out of the condensate lines ... any why you shouldn't just tap a condensate line directly into a sewer waste sack or vent stack like in an attic). To keep air from blowing out of the condensate lines there is usually a trap in the line. It's not required to vent this trap like you would plumbing fixture waste line traps ... since there shouldn't be the risk of sewer gas backing up through the lines, and there generally isn't enough flow/pressure to suck the condensate trap dry. Although it's not required, many consider it good practice to install an open or removable section of pipe that comes up from the condensate line in order to clean out the lines if they appear to be clogged (aka condensate "cleanout"). This can be an open section of pipe after the condensate trap, or a removable capped section of pipe if it's before the trap. That way conditioned air will not blow out of the condensate cleanout. So what I think you are describing is actually a cleanout for the condensate lines, and not a vent. And it shouldn't be blowing any air at all with a trap in the line and a correctly installed condensate cleanout. JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Here is the pic. It is blowing quite a bit.
Thanks |
"Houston we have a problem"
What you got there is a sealed burner "Condensing" Category 4 FAU ... I see a "tee" at the bottom of the "exhaust" that is connected directly into a condensation drain line... Hmmm Think about this .. That pressure is coming from the blower motor out through the "tee" fitting at the top. Why is it done that way???... This is a case of MFG installation instructions review and possible incorrect installation practice.. I have never seen such a large direct connection from the exhaust to the conensate drain line like that... maybe a small drain tube but never that Huge "tee"... ![]() Anyone. |
Check this out:
| Capped drain line vent | rdawes | Inspecting HVAC Systems | 3 | 4/21/07 8:00 PM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 10:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
