Old 9/23/08, 6:21 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default condensation issue at TEV
I've come across this problem a few times recently. Ceiling mounted air handler with dripping of condensation from the refregertant line fittings onto the insulation of the coverpanel. What can be done to limit the condensation without affecting the effiency of the unit.
www.mauihomeinspections.com
condensation-issue-tev-ceiling1715.jpg   condensation-issue-tev-ceiling1714.jpg
Old 9/23/08, 7:46 PM
David A. Andersen's Avatar
Default Re: condensation issue at TEV
Insulate it with closed cell foam tape designed for the purpose.
BPI# 5015804
Old 9/23/08, 10:50 PM
Charley L. Bottger's Avatar
Cork press tape is better the foam pops loose over time
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/24/08, 2:01 AM
Unmoderated Guest
Thanks
Old 9/24/08, 12:40 PM
That black sticky stuff for reefers is best, but is hell to get off over time.
Just don't seal off the nut at the bottom of the valve.
BPI# 5015804
Old 9/24/08, 2:03 PM
Unmoderated Guest
This seems to be a design or install defect as I never see any insulation wrapped around these areas and every one I inspect is dripping. My concern is these units are installed in 150-200 unit condo projects. Where would I find install instructions that spell out how to handle this issue.
Old 9/24/08, 2:58 PM
Copeland Blue Book.
Any TXV Mfg, Sporland etc...
The problem is the air passing by the valve is excessively humid. It is right next to the fans!
It just needs some thermal tape installed.
BPI# 5015804
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Cutler-Hammer CH breaker issue Marc D. Shunk Electrical Inspections 4 5/27/07 2:04 PM
