Old 2/7/07, 7:12 PM
thejnicki's Avatar
thejnicki thejnicki is offline
Default Condensation Line Drainage Problem
Condensation line runs horizontal for about 2 ft , has a 90 and runs horizontal for about 6 ft and then goes under the home with another 90 to drain at the exterior.. And to boot it was only 50 degrees outisde so I did not run the AC..
Im looking for some comments on how and why to write this up, I think the line will back up personaly..
Timothy Hejnicki
All-Specs Property Inspections
(707) 428-3544
Old 2/7/07, 7:26 PM
Charley L. Bottger's Avatar
Default Re: Condensation Line Drainage Problem
Tim why would you want to write it up unless it is traveling up hill do not appear in the pic to be wrong.
You see the stand pipe with the cap installed that is for bleach to keep the cold water slim from building in the condensate line. All A/C units will form a slim and stop up over time. Recommend that bleach be added at least twice during the cooling season.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 2/7/07, 7:32 PM
thejnicki's Avatar
My concern was the amount of 90's i found..
Thanks for the bleach insider.
Timothy Hejnicki
(707) 428-3544
Old 2/7/07, 7:40 PM
Tim If I was overly concerned that it did not drain properly I would pour a little water down the stand pipe and watch to see if it appeared outside????
NACHI Member
State License # 130
Old 2/7/07, 8:58 PM
Joe Funderburk, CMI's Avatar
Water should be able to make a 90 degree turn. I'm not aware of any rule about the number of bends.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/7/07, 10:18 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
if this was for a tpr valve, there would be concern.
since the condensate is not under any pressure, so to speak, i see no issue.
as long as it can drain via gravity, all is fine.
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
Excessive AC Condensation Problem kweiss Inspecting HVAC Systems 8 8/6/07 9:15 AM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
condensation line Rafael Exterior Inspections 8 8/20/06 1:41 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
