I know it's wrong, but what are the ramifications when the condenser fan turning/rotating the wrong direction?
I've only come across this one other time in all my years. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
Reduced efficiency.
Thanks Mike, I figured that much.
From the " if you can't blind them with science, baffle them with BS school of philosophy" I'd like to think this helps ......................... but we all know better Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I remember replacing one on my old house years ago, I used one of those universal motors that had lots of extra wires. It ran backwards until I swapped a few wires around.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
A fan blade is designed to run in one direction, otherwise it only moves about half of the air it should be. That coupled with the dynamics of a condenser unit design, the ambient air is going to balloon or mushroom inside the unit rather than go out through the coils effectively. High heat build up, high head pressures, inefficient is an understatement. I am surprised it is still working, judging from the rusty casing on the condenser moter, it appears to have been there for a while. I had one lady build a wooden box around her outside unit with a few holes drilled in it and then could not make her understand why her Heat pump sucked (really really sucked) at cooling the house. Air flow is the critical factor in HVAC. The air is the medium that carries the heat away or brings it in, in the case of a heat pump. You start screwing with air flow, watch all the efficiency fall away. Homeowners never think of the HVAC until it stops working but it is the most abused / neglected piece of equipment in the home....and the most expensive.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
It's not a heat-pump, but a relatively new unit manufactured in 2000 (house built in 2001) and wasn't cooling as well as I expected it should, with only about a 14 degree temp difference.
The "efficiency" issue was pretty obvious in my mind, but I also assumed there must have been a wiring "error." I appreciate the input. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
A 14 degree differential is fine in my book. |
18 is generally were I expect to see it - especially with newer systems. I don't consider 14 to be a defect, just less than I would expect.
Did it use R410? Those were around in 2000 but were an upgrade.
Its not just the R410 that gives better temp diff's but the overall design of those units, they are awesome compared to the old 10 seer units. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I have no idea Bruce.
Hi Dave, you have to factor in location, and seasonal variations. down here (and California) and many of the southern states a 14 degree Delta T just doesn't overcome the homes cooling losses/ thermal gain, in NE you are mostly trying to cool down from high 80's at relatively low humidity, down here we are trying to cool from high 90's at 90%+ humidity. efficiency is king down here or the unit has to run all day.
Ya, we don't get in the high 90's very often. Lately, we've been getting so much damn rain, it's been pissing me off. |
| HVAC condenser clearances | cfolsom | Inspecting HVAC Systems | 7 | 11/22/07 3:03 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
| oily reside on condenser valve | Mel Olinsky | Inspecting HVAC Systems | 2 | 7/13/07 7:01 PM |
| Condenser unit not level | loconnor | Inspecting HVAC Systems | 5 | 6/5/06 1:36 PM |
