What is the correct term for this part.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
I believe you are referring to the filter drier
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Correct. Thanks. the name slipped my mind.
Not that it really matters, but that is a suction line filter.
There is also a filter/dryer that is installed on the small liquid line. This one needs removal before it leaks refrigerant (if not already leaking). A few more notes: A suction line filter should not be installed on a heat pump on the external piping of the unit. It must be between the compressor and the reversing valve. A liquid line dryer should never be located between the compressor and the condensing coil. Suction line filters can be removed and not replaced. They are used for contamination clean up after compressor failure to protect the new compressor from the crap of the old one. |
| near correct condensate drain | bking | Inspecting HVAC Systems | 2 | 9/19/07 1:51 PM |
| Correct connect at Furnace | tmartens | Plumbing Inspections | 2 | 5/1/07 9:33 PM |
| First to answer this question substantially correct wins a NACHI Beam. $109 value. | gromicko | Miscellaneous Discussion for Inspectors | 28 | 1/30/07 4:30 PM |
| First to answer this question substantially correct wins a NACHI Beam. $109 value. | gromicko | Miscellaneous Discussion for Inspectors | 18 | 1/22/07 8:55 PM |
| Help with correct term? | cvowell | Plumbing Inspections | 11 | 6/1/06 3:15 PM |
