What would the cause of the corrosion above the furnace? There was also some debris below the flue on top of the cabinet and the flue looked fine with no evidence of corrosion.
There is no central air. Could it be high humidity. Dirty ducts. I dont know & need some help. Thanks |
Condensation can collect there. The "corrosion" could be airborne particles that remain after the moisture has evaporated. Same with the rust.
Thanks Jae
You could get moisture from a crack in the heat exchanger,How old was the furnace.Matt
12 year old comfort maker. Heat exchanger not visible to inspect. Flame pattern looked good.
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| To hot too test the furnace | rcooke | Canadian Inspectors | 1 | 8/19/07 11:44 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 9:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
