Old 5/1/09, 7:41 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default CSST
Can CSST pass through a wall and a deck rim joist? Should there be a drip leg on this garage overhead heat?
Thanks!
corrugated-stainless-steel-tubing-100_5190.jpg   corrugated-stainless-steel-tubing-100_5247.jpg   corrugated-stainless-steel-tubing-100_5249.jpg
Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America)
Old 5/1/09, 7:47 PM
Default Re: CSST
Yes, but, typically needs a sleeve.
Thanks!
Some areas require one and some don't. Check locally.
Larry Kage, CMI
231 929 3525
Old 5/5/09, 6:50 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: CSST
Don't forget the bonding grounding requirement.
http://www.nachi.org/forum/f19/prope...-tubing-21846/
Old 5/11/09, 7:19 PM
jallcroft jallcroft is offline
Default Re: CSST
Regarding the 3rd pic, I believe there should be a dirt leg before the gas valve (unless that is not a gas valve I am looking at) and, is that pipe dope in the threads of the union? I was once warned that one should be ‘wary’ of the installation if there is pipe in the threads of a union.
Old 5/11/09, 9:18 PM
John L. Harrison John L. Harrison is offline
Please Note: John L. Harrison is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: CSST
Typically the threads of a union should not have any pipe dope or thread tape placed on them. This could cause interference with the sealing of the union.
Does anyone call out CSST in high lightning areas like Florida? gromicko Plumbing Inspections 13 1/31/12 10:37 PM
CSST Class Action jhagarty Inspecting HVAC Systems 31 1/31/12 12:15 AM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 6:24 PM
CSST Fuel Gas Supply jhagarty Plumbing Inspections 2 4/24/07 10:38 AM
CSST gas pipe rtruluck Inspecting HVAC Systems 2 11/14/06 12:48 PM
