http://www.pddocs.com/csst/faq.aspx
What is the Class Action about? The lawsuit claims that CSST poses an unreasonable risk of fire due to lightning strikes. Plaintiffs allege that the CSST tubing is not thick enough to prevent damage to the CSST in the event of a lightning strike and that Defendants failed to warn consumers about these alleged dangers. The Settling Defendants deny these allegations and assert that their CSST is safe if properly installed in accordance with local codes and the manufacturers’ instructions. ![]() Is there more than one brand of CSST involved? Yes. The CSST installed on your property may have been manufactured by Titeflex, Ward, OmegaFlex, or Parker Hannifin. Titeflex's CSST is stamped with the mark “GASTITE.” Ward's CSST is stamped with the mark “WARDFLEX.” OmegaFlex's CSST is stamped with the marks “TRACPIPE” or “COUNTERSTRIKE.” Parker Hannifin's CSST is stamped with the mark “PARFLEX.” Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
rdawes is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks for that link. Interesting.
Thanks Joe,
I wonder how many instances there are of this tubing being affected by lightening? Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
That was ... en-lightning
Thank you Mr. Hagarty. I appreciate you taking the time to post this info.
Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
Interesting indeed. It appears the real issue is with the installation methods. Proper bonding of the system is the apparent remedy.
In my area (Los Angeles County), based on our LDZ, consumers will be allotted $200 (for a home less than 3000 sq ft) toward the purchase and installation of a lightning protection system. I will be preparing a new narrative for my report system to include this information. Thanks Joe. FWIW - CSST has not been approved for use in CA although many local jurisdictions are allowing it by "special permission." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I just inspected a home today that was LOADED with this Gastite yellow hose...
Comments on this proposed narrative?
"A gas piping system called CSST is present in this home. CSST is used to transmit gas in residential, commercial and industrial structures. CSST consists of a continuous, flexible, stainless steel pipe, and typically is covered with a yellow exterior plastic coating. In the case of one of the products manufactured by OmegaFlex, called "COUNTERSTRIKE," the product is covered with a black exterior coating with yellow lettering. CSST typically is routed beneath, through and alongside floor joists, inside interior wall cavities and on top of ceiling joists in attic space from a gas source to an appliance. CSST does not include gas-appliance connectors (e.g., a connector that runs from a gas outlet to an appliance). Titeflex's CSST product is known as "GASTITE," Ward's CSST product is known as "WARDFLEX," OmegaFlex’s CSST is known as "TRACPIPE" or "COUNTERSTRIKE," and Parker Hannifin’s CSST product is known as "PARFLEX." Typically, these products may be visible along floor joists, above basements, in attic spaces, or connected to exposed appliances such as water heaters. The piping should be stamped with a manufacturer’s mark. We may not attempt to identify the type of CSST present and more than one brand may be involved." "A lawsuit claims that CSST poses an unreasonable risk of fire due to lightning strikes. The plaintiffs allege that the CSST tubing is not thick enough to prevent damage to the CSST in the event of a lightning strike and that manufacturers failed to warn consumers about these alleged dangers. The manufacturers deny these allegations and assert that their CSST is safe if properly installed in accordance with local codes and the manufacturers’ instructions. Nevertheless, the lawsuit was settled and affects any and all persons and/or entities who own structures in the United States in which CSST manufactured by the Settling Defendants was installed as of September 5, 2006. We take no position on the lawsuit and may not determine whether the CSST observed in this residence is covered by the lawsuit. You should trace the CSST in this home and determine the manufacturer for yourself. We recommend that you read the details of the lawsuit and settlement, which can be viewed at: http://www.pddocs.com/csst/faq.aspx#" “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 11/25/06 at 10:17 AM.. |
Let me ask a some general questions here.
Can we possibly be aware of all the potential recalls and lawsuits against products that may be in our clients homes? While I believe we should limit our liablility by careful and informed report writing, just how far should we go? Any and all comments and discussion welcome. Inquiring minds want to know. |
Here's an old article on this topic in a suburb of Dallas, TX
http://www.selectinspect.com/pdf/FRI...pipe%20ban.pdf I was in contact with Gastite and Frisco Building Dept. during these investigations. It was found in all cases the cause was improper bonding and lightning protection. Once this was and is accomplished there have been no further incidences documented in Frisco and CSST systems are being installed today, in my market anyway. JDF, You may need to revise your statement not all are covered please read the bold: Who is covered by the Proposed Settlement? The Settlement Class consists of any and all persons and/or entities who own structures in the United States in which CSST manufactured by Settling Defendants was installed as of September 5, 2006 (“Settlement Class Members”). The following persons are excluded from the Settlement Class: a) persons and/or entities who timely opt-out of this proceeding following the directions for opting-out established by the Court; b) any and all federal, state, and/or local governments, including, but not limited to, their departments, agencies, divisions, bureaus, boards, sections, groups, counsels and/or subdivisions; c) any currently sitting Arkansas state court judges and/or justices and/or any persons within the third degree of consanguinity (blood relationship) to such judges and/or justices; d) Settling Defendants; e) Plaintiffs’ Counsel and their immediate families; and f) any person or entity who as of September 5, 2006, has an individual personal injury, product liability or subrogation lawsuit pending against any of the Settling Defendants in which injury or damage is alleged to have occurred as a result of a failure of CSST resulting from an actual or near lightning strike. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 11/25/06 at 11:32 AM.. Reason: could |
You do not have permission to access http://www.selectinspect.com/pdf/FRI...pipe%20ban.pdf Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
FRISCO Gas pipe ban.pdf |
Here is my version of the narrative:
I like it Brian.
| Proposed Class Action Settlement "Sears" Anti-tip Device | mcyr | General Inspection Discussion | 3 | 11/8/07 6:18 AM |
| MAR is Publicly Backing Away from HI Licensing Bill | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 18 | 4/5/07 11:40 PM |
| CSST Class Action | jcahill | Electrical Inspections | 1 | 11/27/06 8:11 AM |
