Old 3/28/09, 10:06 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default CSST gas lines
Would you say these hanging CSST gas pipe were a defect?
Thanks!
corrugated-stainless-steel-tubing-gas-lines-unprotected-csst-gas-line-front-basement-furnaces.jpg
Find an InterNACHI certified Louisiana Home Inspector (and anywhere else in North America)
Old 3/28/09, 10:19 AM
rmccullough rmccullough is offline
Default Re: CSST gas lines
That is a recognized type of interior gas pipe. To small a picture for support locations. May need additional supports.
Old 3/28/09, 11:41 AM
Jeffrey R. Pope's Avatar
Not based on anything that I can see in the picture. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/28/09, 12:06 PM
Randy A. Hagemo Randy A. Hagemo is offline
From the photo, it does not appear that the gas line is secured to either of the joists. Gastite specifies horizontal runs be support every 6' for 1/2" and 8' for 3/4" line. If its not supported, it should be. If it is, then it is not an issue.
Old 3/28/09, 12:09 PM
I reported they were not supported.
Old 3/28/09, 4:32 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
The Tracpipe installation manual http://www.omegaflex.com/trac/techni..._OmegaFlex.pdf requires vertical support every 10 feet. Horizontal runs must be supported every 4 feet for 3/8th inch diameter, 6 feet for 1/2 inch diameter and 8 feet for 3/4, 1, 1-1/4, 1-1/2 and 2 inch diameters
Old 3/30/09, 9:28 PM
Bruce A. King's Avatar
More important issues for csst: (we have lots of it around here)
Everyone should know all of the following when inspecting homes with csst.
Did the house have any additional bonding for the gas lines?
If not, did you recommend it as an upgrade?
Do you know if and when the additional bonding was required in your area?
Do you know the difference between basic bonding on gas piping and additional bonding?
Do you know how the basic bonding is achieved?
Do you know how additional bonding is achieved?
www.BAKingHomeInspections.com
704 301-3207
Old 3/31/09, 12:29 AM
tphillips's Avatar
tphillips tphillips is offline
Fill us all in Bruce
T & D Inspection Service
Serving the Chippewa Valley and beyond
http://www.eauclairehomeinspector.com
Old 3/31/09, 11:26 PM
The basic bonding is usually present but not visible unless you remove the furnace cover and also a small cover over the electrical connections. The equipment grounding wire should be attached to the furnace cabinet. This is poor bonding since the connection also relies on the furnace gas valve metal connection to provide the bonding over to the gas piping.
In many areas, it is now required to have "additional bonding" for the regular yellow csst piping. The black "counterstrike csst" piping sold by Omegaflex and TracPipe does not need the additional bonding in my area but I expect this to eventually change.
The additional bonding (equipotential bonding) typically requires a #6 or larger copper conductor between the main black iron gas pipe (with proper type clamp) at the meter and connected to the exisitng electrical ground rod. Some AHJ's are allowing it to connect inside the main panel but this technically does not provide 100 percent equipotential bonding as recommended by all (or some?) of the csst manufacturers.
I always include an upgrade for these also:
http://www.gasbreaker.com/
csst info:
704 301-3207
CSST Class Action jhagarty Inspecting HVAC Systems 31 1/31/12 1:15 AM
Gas supply lines to water heaters. dkoehl Plumbing Inspections 5 3/6/11 3:07 AM
Blackened Copper Lines thejnicki Plumbing Inspections 3 8/1/06 10:47 AM
