Old 5/28/09, 5:01 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Crawlspace furnace
Furnace laying directly on the dirt floor of crawlspace.
Thanks!
Find an InterNACHI certified Colorado Home Inspector (and anywhere else in North America)
Old 5/28/09, 5:14 PM
Default Re: Crawlspace furnace
Thanks!
Well, that's not a good plan.
It looks like single wall vent pipe there too.
Larry Kage, CMI
231 929 3525
Old 5/28/09, 6:52 PM
Good eye! It was and passes through the pantry.
Old 5/29/09, 4:56 PM
rdimmerling rdimmerling is offline
saves space and is easy to install....looks pretty good
Richie Dimmerling II, P.E., S.I.
Inspection Engineer
614.309.7552
Old 5/29/09, 6:25 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Should be pretty easy to change the filters on that bugger. I have seen a few like that in our city as well.
Old 5/30/09, 11:38 AM
That type of installation is pretty common around here, although they are usually sitting on bricks or blocks depending on the space available. At least this one is on a gravel bed, which should work out ok as long as there is no water under the house. Of course, we can't see if there is a vapor barrier in place as it should be.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 5/30/09, 5:52 PM
Frank,
No vapor barrier installed
Old 5/30/09, 6:30 PM
Do you have a readily accessible area directly in front of the burners? Looked like the cast iron pipe stops that.
Old 5/31/09, 5:04 PM
No, wrote that also.
Height of Horizontal Furnace in Crawlspace bhartley Inspecting HVAC Systems 4 3/21/08 5:55 AM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
Horizontal furnace in the foundation crawlspace kswift Inspecting HVAC Systems 43 7/24/06 9:26 PM
