Old 9/27/07, 11:06 PM
Bruce A. King's Avatar
Default damper on fan assist flue
Is this damper necessary?
It hinges easily when touched...
Its located between the furnace and the fan assist blower.
(The blower is located at the flue end where it exits the crawlspace.)
The blower has control wires that appear to be wired to shut off the unit if the blower quits.
www.BAKingHomeInspections.com
704 301-3207
Old 9/27/07, 11:15 PM
Marc D. Shunk's Avatar
Banned
Default Re: damper on fan assist flue
That's commonly called a "Field control", which is a slang term derived from the main manufacturer of such devices. It's weighted, and used to control the over fire draft of fossil fuel burning appliances. It maintains an even draft, without regard to how many appliances are operating or how hard the wind is blowing outside.
http://www.fieldcontrols.com/draftcontrol.php
Old 9/27/07, 11:36 PM
Michael Larson's Avatar
If it's a barometric draft damper I don't see the weight or it's adjustment.
7M Field Draft Control
For oil or coal fired residential heating applications. Designed for settings from 0.01" to 0.1". Features an infinitely variable screw adjustment. Employs side wings to control air direction with gate curvatures designed to compensate for differences inhorizontal and vertical settings. This 7M Field Draft Control is one of many top quality items in our Stove Pipe Fittings - Black department.
Old 9/27/07, 11:53 PM
Thanks, this page looks like the one, see 2nd page down, rt side picture showing the supplemental air intake
http://www.fieldcontrols.com/venting.php
704 301-3207
Old 9/28/07, 12:07 AM
Banned
That would make sense in your case, since you had a power venter on the end. Probably needed that to keep from sucking some crazy high over fire draft at the furnace. That Field control probably tilts open a wee bit when the drafter motor turns on.
Old 9/29/07, 12:43 PM
Banned
Some barometric dampers have the adjustable weights on the inside of the damper.
Old 9/29/07, 1:07 PM
Roy D. Cooke, Sr's Avatar
Some you adjust by turning the whole damper so the axis is on an angle.
They work just as well as the ones with adjustable weight.
. Cookie
Old 9/29/07, 2:18 PM
Thanks, I haven't seen the other types yet.
How many gas/oil appliances can vent into 1 flue? jberthiaume Inspecting HVAC Systems 7 10/17/07 11:09 AM
Soot from Barometric Draft Damper (posted by Ted Hull) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 5/11/07 7:49 AM
Cracked flue tile bknowlton Inspecting HVAC Systems 6 2/2/07 12:37 AM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/21/07 12:29 AM
Gas Log Flue venting height. lagudo Inspecting HVAC Systems 34 4/7/06 2:42 AM
