Well, i actually don't want to date it...My wife wouldn't be very happy with me. It might be a little younger than she is....
Model No: 867.769224 S/N: H611 39071 Usually I would expect the YY/MM to be decipherable from the S/N but these numbers don't make much sence. It's a 90% efficient model taking the combustion air from indoors and exhausting the combustion gasses via a PVC exhaust pipe out the side of the home. Thank you in advance for your help! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
I wanted to date a Goettl Heat Pump once !!!
Does it have another mfr name besides Sears/Kenmore? If it is made by Trane or American Standard it could be 1993. I was thinking Sears stuff had a date on their tag.... I guess I'm wrong.
Bruce Bruce Thompson Professional Inspector, Lic. #9199 Serving Tyler, Lindale, Bullard, Whitehouse, Mineola and the surrounding East Texas area. www.TylerHomeInspector.com NACHI 06081394 |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't help you with the date, but the manufacturer looks like Tempstar
Thank-you! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Hi to all
The model number is a Sears one, and if I understand the BLACKHORSE date coding corectly from the serial # that would make it a 1986 model. Where's Russel when you need him Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
If it's an 86, I would have made a different notation in my report. With furnaces lasting 25 to 20 years, an 86 is at the end of it's life and it would be a good idea to start budgeting for a new one now rather than waiting a couple of years to start the budget process.
The info sheet on the home included, "Newer furnace, A/C, and electrical." and I didn't believe it. That's why this one is important. Thanks! Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
However, I believe you have a newer unit based on three factors: (1) model number, (2) type of serial number, and (3) your description of the unit as a high-efficiency model with PVC exhaust pipe. Consequently, I'm going with August 2006. However, I could be wrong. My other choices, in order: August 1996 June 1986 I'm still going with August 2006. #3 above, to me, really is a defining factor in determining the date. NACHI 2005 U.S. Member of the Year
Russel, according to Prestons guide Sears stopped using purely numeric model #'s in 1990/1991 and switched to a mixed Alpha-numeric, like yourself I am somewhat surprised to be thinking of a HE furnace from the mid 80's. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Sorry, they are not my type!
Virtually everything "made by Sears" is now made by someone else and that someone else also takes responsibility ("Problem with your ________. Just call these folks: __________") and typically those are the numbers that show up on the Sears nameplates now. Decoding "Sears" is difficult post 1990-91. But as my wise ol' grandmother said, "It sure is a lot of fun!" NACHI 2005 U.S. Member of the Year
| Sears Furnace age | menser | Inspecting HVAC Systems | 3 | 4/12/07 5:17 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Sears furnace age... | jweinberg | Inspecting HVAC Systems | 3 | 3/31/06 10:42 AM |
