First one is the wires leaving the 60 amp breaker and going to the heat strips.
Second is the top heat strip. 5 KW Loose connections? Should they be that hot? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is that first one a parallel circuit? Two wires feeding the same equipment? (3 phase, 2 wires per leg feeding the same heaters)
If so, the hot one is not your problem. You have a bad connection on the cool conductor. 2nd pic looks like a thermal overload? Need amperage on both of these. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
and yes since I went beyond and removed the cover, I found the great use of jumpers for interconnecting service breakers. It was a 1989 Janitrol BTW... It seemed to work just fine.. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I would say #1 is a bad crimp on the spade connector.
#2 is at the overloads. The center bank is not on (yet), or bad. The top one comes on first. The others are on a timed sequence so they will show up at different temps at initial start up. The rust will also look hotter than clean components. That hot nut is connected directly to the heater coil. I would expect it to get very hot. From the looks of it, the middle bank has never been used. It may not be hooked up. That is a lot of heat banks for TN if it is a heat pump. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
They can figure that one out when the fix the jumpers.
The home was about 2600 sf top and basement. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
What jumper were you talking about the one from the incoming power to the second set of breakers. I sure wish ya would buy a amp meter Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
and yes I will get an amp meter for you.. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Ok I am done with the jokes what I see on your Jan-A-junk. is loose connections those spade clips have a tendency over time with a little heat to just expand out like a ripe banana or like Dave stated a bad crimp. Does appear the the middle strip was not operating but can not tell 100% with out a amp reading. Did I mention amp reading. Ya were a bit out of focus on your images but not enough to create those kinds of temps.
Ya can't call that double tapping on a service connect to a elec furnace that is how they feed all of the strips from a single power source
Charley & Dave's Rule of IR: If you don't do anything else, focus the camera and take an amp reading on any and all electrical scans.
Otherwise we will fling a dart at the dart board and give you a wild *** guess... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Oh BTW just wanted to say if ya keep doing the things you are doing above and beyond what is required you will become a sought after HI just from word of mouth. That was a good find in that strip heat most would never have found it just taking temps at the register. Keep up the good work
When he gets know as an undesirable in Knoxville for finding too much stuff that is actually wrong, let me know and I'll come work with him and we can just work the important jobs.
Writing a $1,300 report from yesterday and getting set for a $2,600 "home inspection" tomorrow... (don't get to many "Home Inspections" these days I'm too busy doing all the crap that we are not supposed to do...) If the Feds don't quit messing with my retirement, I'll have to spread out and work longer... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
2 different gauge wires also. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| A letter from David Letterman... | jwilliams4 | Miscellaneous Discussion for Inspectors | 9 | 11/3/08 8:55 PM |
