View Poll Results: Is the picture showing a defect?
Duh of course it is not a defect, we always do it that way. 3 6.98%
Duh, of course it is a defect. 29 67.44%
I am a plumber. 11 25.58%
Voters: 43. You may not vote on this poll
Old 4/21/08, 12:14 PM
Brian E. Kelly's Avatar
Default Defect?
Is it a defect
Old 4/21/08, 12:32 PM
Michael R. Boyett's Avatar
Default Re: Defect?
See this recent thread on the same subject: http://www.nachi.org/forum/f20/agents-says-heating-venting-air-conditioning-guy-told-her-code-27259/ ,i.e. post #8. Yep, I'd write it up if it were taped and especially if the tape were deteriorated as shown.
Old 4/21/08, 12:46 PM
Default Re: Defect?
To: dwelling.doctors@cox.net
Subject: 3064 ***********
Size: 4 KB Brian,
I just thought I would let you know that I had a HVAC tech look at the inspection report on this property at item 7.2
He said those wires mean that the condenser fan has been replaced and they do it like that all the time. When they replace it and hook up the wires, they never know which way the fan will blow and if it blows wrong then they just undo the wiring and rewire it. If they don't leave them out like that then they have to take it all apart again. Just about anytime the fan has been replace then the wiring will look like that. If you have any questions about it I can have him call you.
Thanks for doing the inspection, my buyer felt very comfortable with you and your report looks very nice!
Thanks again,
Marcia ********************************
Any questions???????????????
Old 4/21/08, 1:08 PM
Default Re: Defect?
Yes, but did that MORON put it on letter head and sign it? someone should call him and let him know about the control panel. That is so far from the truth it is not even funny.
We used to call these guys stationwagon mechanics.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/21/08, 4:07 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Default Re: Defect?
It was done in an unworkman like manner??
DUH
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 4/21/08, 4:35 PM
klott's Avatar
klott klott is offline
Default Re: Defect?
Won't that cause the Toilet to overflow?
Old 4/21/08, 9:07 PM
James E. Braun, CMI's Avatar
Default Re: Defect?
Most condensing fan motors run only one way because the condensing fan, on an unit like that, has blades only pitched one way. You would have to order a special motor and it would cost a lot extra to turn the opposite way. I use to own a HVAC company and I was the one who ordered the motors we stocked in the vans with. We carried every common motor with us and it was the blower motors that would be an odd ball every once in a while.
Old 4/21/08, 11:28 PM
Jeffrey R. Jonas's Avatar
Default Re: Defect?
Originally Posted by bkelly2
Is it a defect
Let me see... how do I say this? "Damn straight" it's a defect!!!
Old 4/22/08, 1:13 AM
Barry Adair's Avatar
Default Re: Defect?
I like plumbers, they go with the flow...or can get the flow to go and all I know say payday's on Friday
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/22/08, 8:30 AM
David A. Andersen's Avatar
Default Re: Defect?
That's so you can blow the grass clippings out of the coil!
Just stick it in reverse and out it goes!
Or maybe it's to adjust for when the day sucks or blows?
Old 4/22/08, 1:05 PM
Wild Leg Wild Leg is offline
Please Note: Wild Leg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Defect?
I understand the "parts changer's" logic in leaving them sticking out of the top of the unit (pure laziness, no pride in workmanship, etc), but I can't justify purposefully leaving wires sticking out of the top of a unit.
I wonder what an insurance adjuster would say, if some kid decided to play with those wires and helped them find a path to ground?
If nothing else, it is just ugly!
What are the pipes sticking out of the wall behind the unit?
If they are refrigerant piping, they need some insulation.
Regardless of what they are, the penetration looks suspect.
Old 4/24/08, 10:49 PM
William Warner's Avatar
William Warner William Warner is offline
Default Re: Defect?
This would have received my stamp of disapproval!
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 4/27/08, 9:41 AM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Defect?
The tech said they didn't know which direction the motor would rotate???? The written directions for these motors state which rotation they are wired for. Maybe the technician needs to take some remedial reading classes.
Old 4/27/08, 10:30 AM
Default Re: Defect?
It tells you the direction but does not "explain" shaft/lead end of observation!
Is inadequate roof or attic ventilation a defect? gliebig Exterior Inspections 85 1/16/08 6:56 PM
Can you find the defect.... dmacy Plumbing Inspections 7 3/21/07 5:57 PM
Shingle defect? gschatz Exterior Inspections 9 5/12/06 4:57 PM
Homeowner special....defect or just informational? tneumann Plumbing Inspections 7 2/9/06 2:32 AM
