Old 2/12/08, 6:00 PM
John Evans John Evans is offline
Default Defective Heat Exchanger, Flue Connection, etc
Lack of proper flue connection at the masonry chimney. Extreme amount of rusted metal indicating defective heat exchanger. And the gas valve was leaking. Quite a candidate for carbon monoxide! Showed all of the problems to the owner, buyer and agents. The owner stated that he plans to replace the gas furnace, but was in no hurry to resolve the problems. I could not beleive there was no sense of urgency to resolve these very serious safety issues. defective-heat-exchanger-flue-connection-etc-woodley-0.jpg
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 2/12/08, 11:38 PM
Charley L. Bottger's Avatar
Default Re: Defective Heat Exchanger, Flue Connection, etc
Don't think I would stick my neck out that far as to delcare a bad heat exchanger based on rust or a bad flue connection. Rust can and generally is the result of excessive moisture either from a faulty humidifier during the heat season or excessive moisture in the cooling mode. Many heat exchangers will rust and fall to the bottom of the burner barrels and not have a crack.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 11:46 AM
Radiant Ceiling Heat hhull Interior Inspections 6 7/26/07 9:19 AM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
Radiant Heat Transfer rmyers1 Structural Inspections 0 6/1/06 12:21 AM
Cracked Heat Exchanger jallingham Inspecting HVAC Systems 26 5/11/06 11:12 PM
