This 88 year old home had a home made piping system installed at the basement sub floor that I am trying to figure out what they were doing.
One end was not connected. The other end was at the band/sill plate. It looks like garden hoses covered with rubber. There was a 240 volt circuit nearby. There is no A/C system installed. I really have no clue!! Do You?? I would guess home made lines for some type of cooling system. |
Many years ago I did an old home that had running water from a spring.
It went through a big old car rad and then back out side to the ditch. This I guess was the first air conditioner. The had a big fan pushing air through the fan. Could this have been the same? ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Wild Leg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's a wild guess:
Servel (and others) used to make a gas-fired air conditioner that was actually a chiller. It sat outside and using absorption refrigeration, produced cold water. The cold water was pumped indoors to a fan-coil unit, which could then circulate cool air throughout the structure. That's my story & I'm stickin' to it. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is it an optical illusion, or is the wall in pic 1 about to fall over (right side of picture)?
Looks like a partition wall with plumbing pipe (black I bet) used for support.
Most likely a small toolroom. |
| Inspector needed in Burlington, WI - Inspectorocity.com | Melanie Feria | General Inspection Discussion | 0 | 2/28/08 1:34 PM |
| Hire IAQ Professional | dplummer | Ancillary Inspection Services & Additional Topics | 0 | 11/15/07 9:01 AM |
| Volunteer home inspectors needed to help elderly/disabled. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 11/13/06 7:33 AM |
