Hi all,
I'm a newbie inspector and non too happy with the training I got, so I'm trying to fill in with all the nice Nachi online courses. Here is one I'm still not sure on. How do tell whether a system is a heat pump or a regular split system with condenser outside and furnace/air handler inside. Some heat pumps are clearly labeled as such and some aren't. One way to know is if the thermostat has an emergency heating mode then it's clearly a heat pump. Other than that I've gotten mixed information. Thanks in advance for your comments. Tom |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thomas,
You cannot depend on the thermostat because sometimes the wrong one was installed! Look in the compressor/condenser unit (normally outside) for the reversing valve. It is the part that changes the heat pump from summer to winter operations. |
I agree and even some of the newer LCD t'stats don't have a mechanical switch on them for EM Heat. That function is programmable on the display. Look for the reversing valve, it's usually visible and obvious.
I have a 2004 Lennox heat pump system. A/C summer, heat in winter. Forced air gas furnace back-up. No valve like this on my system. Tag on upper furnace duct says heat pump system.
Key in your locations. Systems to your areas may be different. CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
Send some pictures.
You have to have a way to reverse refrigerant flow. Thomas, you will also find a circuit board inside the electrical control compartment of the condensor if it is a HP. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I understand the question, but around here heat pumps are a "regular system". Other than looking for the reversing valve as mentioned above, in most cases you can also look up the model number on the manufacturer's web site.
Frank P. Newman Emerald City Inspections, LLC Dublin, GA Last edited by fnewman; 9/7/10 at 1:23 PM.. |
Why look it up when you can look into the fan housingh and see it?
| PLEASE HELP! Need to change the SOPs, per NEMA | ktarasenko | Electrical Inspections | 76 | 4/19/10 9:15 PM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 293 | 2/10/08 2:20 AM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 11:06 AM |
