Would you call out this vent as being installed too close to combustibles, it less than 12 inches to the mulch. Maybe it is the mulch that is too close to the vent.
Thanks!! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America) |
Probably not. Heat rises and when you think about it, it's also closer to the siding than the mulch.
I agree. The next inspector will find that is covered with bushes & shrubs.
I believe direct vent terminations require 12" above the ground or highest anticipated snow level.
| Variable speed direct vent blower motor | csteele | Inspecting HVAC Systems | 6 | 5/5/08 9:41 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
| Direct vent WH with draft hood | dpeterson | Plumbing Inspections | 9 | 12/30/06 4:35 PM |
