Old 5/1/09, 4:53 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
Default Direct Vent Pellet Stove Help
I don't run across many of these situations around here. The vent pipe is about 7 feet off the sidewalk. Then neighboring home is over 20 feet away. The home is clad in vinyl siding. There is no manual available and was curious if there is a problem with this. To me, it's a DLR (Doesn't look right). Who would be the licensee for refrerral A Chimney Sweep??
Thanks in advance for your help!
direct-vent-pellet-stove-help-woodstoveinteriorjpg.jpg   direct-vent-pellet-stove-help-woodstoveexterior.jpg   direct-vent-pellet-stove-help-woodstoveexterior1.jpg
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America)
Old 5/1/09, 6:44 PM
Michael Larson's Avatar
Default Re: Direct Vent Pellet Stove Help
It DLR to me either but I would defer in any case.
Do you have a make and model for the stove?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 5/1/09, 11:42 PM
Marcel Gratton's Avatar
Greg,
The installation looks OK to me but the siding will discolour from soot and draft may be minimal at times...
On The Level Inspection
Gatineau, Québec
Old 5/2/09, 1:49 AM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
So what keeps the exhaust from blowing back into the window? (Humor me, I know the window would probably be closed when the burner is being used)
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 5/2/09, 3:17 AM
Sure Mike,
Make: Harman Stove
Model: Accentra
From what I could find the 7' requirement works. The nearby window was fixed. Just one of those things that dlr. Thanks for asking.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Old 5/2/09, 7:30 AM
Here is the manual.
http://www.harmanstoves.com/doc/accentram.pdf
It indicates 48" to operable window and 7 ft. above walk and 3 ft. to all combustibles.
Smaller clearances if optional outside air vent is installed.
The clearance diagram is on page 19.
Read it carefully and I am not sure about the vent termination in your pic.
DLR because if has no downturn to prevent rain infiltration.
Michael Larson
Hudson, WI
InspectraPro
and
Old 5/3/09, 10:22 AM
Below copied from page 19 of the installation manual:
B. The clearance to a window or door that may be opened must be a minimum of 48" to the side and 48" below the window/door, and 12" above the window/door. 1
With outside air installed, the clearances are 18" to the side and below and 9" above.
Gatineau, Québec
Old 5/3/09, 11:45 AM
Here is the manual.
Thanks,
I mentioned in the report that they should refer to the manufacturer's reccomendations but there was no manual present. I forwarded the link to the manual to our client. So now they have the reference. I had a brain fahrt not to look that up. There were many other discussions that had me a little distracted.
The clients are from Florida and did not have any experince with Furnaces, Humidifiers, Attics, Basements and this home had all AND the home was built in 1885 with K&T and 2-prong receptacles, sagging floors....
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Pellet Stove venting jcampbell Inspecting HVAC Systems 9 1/24/09 10:14 PM
Variable speed direct vent blower motor csteele Inspecting HVAC Systems 6 5/5/08 9:41 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
Direct vent WH with draft hood dpeterson Plumbing Inspections 9 12/30/06 4:35 PM
