Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 3/31/06, 9:56 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default dirt leg
OK so I know that you have to have a dirt leg on gas lines. I found gas heater today where the dirt leg is in the unit just in front of the gas valve. Never seen this setup.
any thoughts?????
sorry no photo
Old 3/31/06, 10:36 PM
Jeffrey R. Pope's Avatar
Default Re: dirt leg
Drip leg.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/31/06, 10:37 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
what's a dirt leg. i think i missed "it" again. maybe it's me.??
Old 3/31/06, 10:46 PM
Ted Allen Ted Allen is offline
I call it a dirt leg. And less than 35% of homes here built between 1979 and 2001 have it!
Old 3/31/06, 10:51 PM
Dirt legs are not required in any jurisdiction that I know of. Drip legs, however, are required by utility companies when the moisture content is high in the fuel they provide.
I think I may have seen one in four years. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/31/06, 10:59 PM
When I right it up it is a "drip leg", but every plumber I have talked to calls it a "dirt" leg.
Old 3/31/06, 11:01 PM
What else would you expect in AZ. Everything turns to dirt eventually. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/31/06, 11:02 PM
Here, it seems to be plumbers choice. Somtimes it is there and most times it is not. Regardless, I mention it in my report, but no one does anything about it.!
Old 3/31/06, 11:03 PM
Hmmmm, I think AZ will be beach front property before long.
I hope not.
Old 3/31/06, 11:08 PM
I think you meen sand.
Old 3/31/06, 11:21 PM
Joe Funderburk, CMI's Avatar
G2419.2 (408.2) Drips. Where wet gas exists, a drip shall be
provided at any point in the line of pipe where condensate
could collect. A drip shall also be provided at the outlet of the
meter and shall be installed so as to constitute a trap wherein an
accumulation of condensate will shut off the flow of gas before
the condensate will run back into the meter.
G2419.3 (408.3) Location of drips. Drips shall be provided
with ready access to permit cleaning or emptying. A drip shall
not be located where the condensate is subject to freezing.
G2419.4 (408.4) Sediment trap. Where a sediment trap is not
incorporated as part of the gas utilization equipment, a sediment
trap shall be installed downstream of the equipment shutoff
valve as close to the inlet of the equipment as practical. The
sediment trap shall be either a tee fitting with a capped nipple in
the bottom opening of the run of the tee or other device
approved as an effective sediment trap. Illuminating appliances,
ranges, clothes dryers and outdoor grills need not be so equipped.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/1/06, 8:44 AM
Worked for a mech. cont. for 16yrs, always been called a dirt leg and yes I know about the moisture issue.
Old 4/1/06, 9:46 AM
Patrick Bolliger's Avatar
Talking Re: dirt leg
Mandatory in the Chicago area by gas companies. Called "drip legs"...
"Dirt legs" are for our politicians...
Old 4/1/06, 11:57 AM
To answer your original question Bruce, it really doesn't matter where the drip leg is located, but it should be accessible.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/1/06, 12:27 PM
Thanks JP just never seen one in the unit.
Does it need a Dirt Leg? (condensate trap) mgault Plumbing 8 7/20/07 7:52 AM
Tee Vent connection & dirt leg. dmacy HVAC 4 6/13/06 11:12 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
