rmc3inspection is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is the minimum height from the ground of a disconnect for the condenser/compressor unit of an HVAC system?
I found one today that was 4 1/2 inches from the ground mounted on the masonry block foundation wall. Any help is appreciated. Thanks, Reese |
No code on that, but I try to keep it at a comfortable kneeling height to work on in the future, which also keeps it up out of all but the worst snowfalls. That's generally around 30" or so. Four or five inches off grade is just goofy. That makes me think the sparky hung the disco before the final grade was done, and everyone just went along. That's ripe for getting whacked with lawn maintenance equipment.
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I've sought out that same answer. I always installed them at a height around 3' to 3.5’ above grade. I recently wrote up a disconnect that was (at the bottom 2" above grade) I can't find anything in the IRC. Common sense dictates that you would want it at a height that is above typical snow depths (like Marc said) and is high enough for easy access. I didn’t have a code to guide me so I relied on common sense. I’m surprised some governing body hasn’t addressed this.
James R Lilly, CMIA www.lhiservices.com jamesrlilly@lhiservices.com Home and Mold Inspections Radon Testing Based in Parkersburg, WV Serving West Virginia and Ohio |
I have found one (metal box) right on the soil at ground level. So much so the front cover could not be opened without digging out in front of it. I did not attempt to do so, figuring whomever did that may have done something equally stupid at the connections or it had a good chance of it being wet inside.
| Water Heater Height Requirement | Skip Erwin | Plumbing Inspections | 7 | 9/7/07 8:34 PM |
| AC pad have height requirement? | rwashington | Inspecting HVAC Systems | 5 | 10/30/06 10:25 PM |
| height requirement | vsantos | Electrical Inspections | 11 | 4/7/06 4:14 PM |
| Height Requirement for Line from House to Garage. | mlong | Electrical Inspections | 9 | 4/7/06 9:33 AM |
