| View Poll Results: What would you do? | |||
| Leave as is |
14 | 38.89% |
| Place box in shutoff |
0 | 0% |
| Recommend HVAC |
22 | 61.11% |
| What is a shut off? |
0 | 0% |
| Voters: 36. You may not vote on this poll | |||
The home has a 10 year old Lennox heat pump.
When I was inspecting the exterior components I found that the fuses for the disconnect where sitting on top of the shut off box. Being the unit is a heat pump how could it properly heat if the disconnect was pulled? I asked the seller but she had no clue why it was disconnected. I didnt insert the fuses as I feel that there may of been a reason that they where pulled. The 2nd poll column should say place fuses in box. Sorry!! I recommended a HVAC but wanted to post. The exterior unit was full of lint from the dryer vent. Any idea what the copper line is too? All electric home. Last edited by dmacy; 11/30/06 at 6:13 PM.. |
Shutoff valves, circuit breakers, electric outlets, and gas pilots—only a visual inspection of shutoff valves and circuit breakers is done. One not only wants to be safe in one’s new home; safety is a concern while one’s new home is being inspected. Therefore, the Inspector does not turn on any water or gas shutoff valves, move any electric circuit breakers to the “on” position, plug in anything that has been unplugged, or light any gas pilots, simply because it is not known why the valves or breakers were off, why the equipment was unplugged, or why the gas pilots were turned off. Turning on valves and breakers, plugging in equipment, or trying to light gas pilots without such knowledge can cause property damage, personal injury, and, in a worst case scenario, loss of life.
This would also apply to fuses... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
One was a water pump at a cottage. Agent said owner states it is OK to turn on the pump. .No way its off and I am not allowed to turn it on. Agent gets down finds the plug plugs it in and no prime just hummmmmmmm . Well what do we do now she said, suddenly PRIME and water like a fire hydrant all over the kitchen floor. . We get the pump unplugged and try and clean up the water. This summer nice little home owners husband has passed away and the water is shut of to the second floor. Purchaser and I are in the crawl space and he wants the water turned on . Same story sorry I am not allowed he goes upstairs and talks to the lady and she knows nothing he again asks me and same story this time agent, owner and his wife hears me tell sorry . Well he Finely gets the water turned on and you know what, bad seal on toilet upstairs and water every where. Well the water he gets shut of almost . Yep it still leaks and the owner calls the agent he calls me as I am the only one who lives close, next street. I go and shut the water off properly, lucky I had just bought some fresh corn and gave the lady ( She lived alone ) 3 cobs just picked . She was so happy and said to me the purchaser said when she called him about the water . That damed Home inspector should have made sure it was shut off . She said, I new it was not your fault, I heard you tell him three times you could not turn it on . So if you can not see what Jae said you might be better of buying a chip truck . Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
My problem is, I don't know what a chip truck is. Can you help me out? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Chip truck--- charles chips delivered chips in a metal can years ago, like a bread man.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am also interested in what a chip truck is....
If a person can get the correct place and give a good helping they can make enough money in 6 months to take the rest of the years of . It can be long hours but some make big money . </IMG>Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
With gravy and kurd? Pu'tin..is that how you spell it.
When I was in Quebec...french fries w/ brown gravy and white cheese curd....wow was that good. Not as good as the Pike and the Walleye though |
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Deffinatly! Do not turn anything on that is off.. I have stuck by this rule for my short time in the biz and on more than one occasion the Agent will do it for you only to find out that the kitchen is flooded or the furnace is smoking................. Leave the off stuff off especially the gas. |
Short version of a story I heard in a chapter meeting fifteen years ago. Inspector turned on breaker that was tripped. When he finally arrived in detached guest quarters documents in an electric oven were smoldering. Home owner was an attorney, the guest quarters were his office, and he used the oven to store files. Moral to the story? Don't eat chips with mayonaise.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI Author of Manual For a Happy Home & Inspect & Protect |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ahh! Fish n Chips and malt vinegar reminds me of my Air Force days at Bentwaters RAF UK. They also had eel and crab also tasty.
Safety. Write it up for HVAC compant cause if they called me to service guess what is going to get fixed before I start working. |
| Exterior Service Disconnect Clearances? | rcramer | Electrical Inspections | 18 | 7/28/07 1:12 PM |
| 50 amp disconnect for 1600sf condo | kmccullough | Electrical Inspections | 5 | 4/10/07 8:49 PM |
| A/C Disconnect question | rslocum | Inspecting HVAC Systems | 15 | 9/21/06 12:16 AM |
| 100 Amp Meter, 200 Amp Disconnect | jweinberg | Electrical Inspections | 8 | 8/15/06 12:32 PM |
| Disconnect and Main panel | srowe | Electrical Inspections | 10 | 6/13/06 7:49 PM |
