Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 10/7/09, 10:37 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default Disturbing news from my HVAC guy
An HVAC tech was at my mothers home doing a routine maintenance when his elbow brushed against the ac line. He received a shock and started to investigate. He found the outer casing of the AC was reading 105 VOLTS????
after removing everything giving a load he still could not find out why? but he replaces a single pole lennox a the shut off with a double pole. That seemed to mostly fix the problem. There is still some minor voltage , i think he said 15volts. We dont know why the breaker did not trip. Obviously one of the legs is making contact with something it shouldnt.
Has anyone encountered a similar situation? This guy and another veteran of HVAC were baffled.
Joseph Tribuzio 708 456 1423
Tribuzio Home Inspection Services Inc.
Entitiy Lic# 451.000692
ELMWOOD PARK, ILLINOIS
www.thishomeinspector.com
www.thischicago.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America)
Old 10/7/09, 10:41 PM
Doug Edwards,  CMI's Avatar
Default Re: Disturbing news from my HVAC guy
Does this compressor have a heater?
Doug Edwards, CMI
Old 10/7/09, 10:42 PM
Bruce A. King's Avatar
Probably leakage from a conductor in the compressor to the case along with poor bonding of the case to ground. I would also verify proper connections in the panel for this circuits equipment ground.
www.BAKingHomeInspections.com
704 301-3207
Old 10/7/09, 10:51 PM
nope, just a outdoor ac unit.
www.thischicago.com
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 10/7/09, 10:53 PM
The panel is a Wadsworth, I haven't been there to look it over but im still puzzled why it would not trip?
www.thischicago.com
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 10/7/09, 10:57 PM
Andrew T. Shick's Avatar
Andrew T. Shick Andrew T. Shick is online now
Plastic condensor pad?
“Of liberty I would say that, in the whole plenitude of its extent, it is unobstructed action according to our will. But rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual.” - Thomas Jefferson
Old 10/7/09, 11:01 PM
Voltage caused by leakage can have very little current capability available but it sounds like a bad breaker trip level could be present also..
Ever notice how a 14/3 or 12/3 cable will have 30-40 volts on the red wire when it is not connected to anything? This is "crosstalk" or simply leakage along the length of the cable from the black wire induced into the red wire. If you put even a very small load on that stray voltage it will disappear.
704 301-3207
Old 10/7/09, 11:28 PM
Andrew, YEAH it is on a plastic pad.
Bruce, I'm going to take a closer look at that breaker and the grounding/bonding.
The crosstalk sounds like a factor too.
www.thischicago.com
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 10/8/09, 7:23 AM
Wayne B. Wilson's Avatar
Check the ground rod also
Old 10/8/09, 7:37 AM
Ronald l. Cook Ronald l. Cook is offline
Check to see if the capaciter is not starting to short out.
Inspecting Furnaces. Please proof this new inspection article. gromicko HVAC 4 9/15/09 9:54 PM
Bad News--Good News jwilliams4 Misc. Discussion 27 8/21/09 11:29 AM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 8 5/21/07 3:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher HVAC 7 3/8/07 8:17 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
