Old 8/6/06, 1:59 AM
eritter eritter is offline
Please Note: eritter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Do you consider whats Grandfathered?
I know of an inspector that failed the location of a furnace and water heater located in a closet of a ranch house on a crawl space when that was where it was installed in the early 60's when built, which was excepted at the time. Do most fail on issues even though you know it was built that way or do you consider some things as Grandfathered? This inspector was NACHI and ASHI certified. What are your thoughts? I didn't feel it was ethically right, but rather most important to explain to the customer the issue as it stands.
Old 8/6/06, 2:05 AM
Dale Duffy's Avatar
Default Re: Do you consider whats Grandfathered?
Was it drawing combustion air from a habitable space?
Old 8/6/06, 2:11 AM
Best I can say it was a downdraft furnace. The duct work was in the crawl space which is vented, and the return was located in a hallway through the wall above the furnance.
Old 8/6/06, 2:31 AM
Dale Duffy's Avatar
Shouldn't be a problem if it was installed according to the manufactures specifications.
Old 8/6/06, 9:08 AM
Jeff Merritt Jeff Merritt is offline
FAIL? I do not pass /fail anyting, it needs to be reported, not pass or fail, you may be opening yourself up for trouble from seller.
Old 8/6/06, 9:35 AM
gbeaumont's Avatar
Hi to all,
also you would need to know the location of the closet,if it was a bedroom then that would be an issue, if it was in a hallway closet that is not neccesarily a problem.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 8/6/06, 9:54 AM
Barry Adair's Avatar
Grandfather, pass, and fail comes from a Real Estate agent handbook.
I was brought up that "Grandpa's dead and his opinion don't count."
If the inspector thinks the potential for property damage, occupants health and safety, possibility for loss of life, or other mitigating factors are evident during his/hers inspection.
They are stating their opinion whether there is or is not a code in place.
We are not required to have a code to back up our opinion. It helps but is not necessary in all cases.
Example: No code for stinging insects or noxious plants. I have a friend that goes into anaphylactic shock when stung and I have been hospitalized for severe poison ivy outbreak. I note these items when I find them during an inspection.
No SOP, No Code, My Opinion
I work without a net.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/7/06, 12:09 AM
David A. Andersen's Avatar
Just because it was done wrong a long time ago, does not make it right over time. It's still wrong and the client should be given the opportunity to know this.
There is no reason to make a big deal over some things. For example, I find stair systems miss-engineered all the time. That does not mean that we are going to ask for them to be rebuilt. By advising the client ( who is really the only one that knows the dynamics of their family) they can decide if it a matter of concern to them.
If it is, they just need to find another house.
Old 8/7/06, 1:39 PM
Robert J. OConnor's Avatar
Any equipment installed must legally comply with the local codes and standards in effect at the time of installation, no matter what the details or age of the original construction were. However, HI's are not performing a building department code compliance inspection and would not "fail" an installation (or at they shouldn't be doing that), or be overly concerned with if it's a "grandfathered" or "legal" installation. It's really about safety.
Many do use current construction standards and requirements (e.g. model building codes) as a guide to help identify concerns and defects ... no matter how old the installation is or what standards were in effect at that time. So a lot depends on the actual installation details and opinions of the inspector.
JMO & 2-nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 8/7/06, 1:44 PM
rwand1 rwand1 is offline
If one is buying a Victorian farmhouse with a railing on the second floor, and the railing is antique and original I would not be writing it up. Its existing and most savvy purchasers are buying something of that age knowing things just will not pass the muster of the current codes.
Old 8/7/06, 10:15 PM
Brian E. Kelly's Avatar
And when the new child falls through the antique railing, then what?
NO GRANDFATHERING well unless I am doing it to my own grandkids of course.
Old 8/7/06, 10:21 PM
Same here...with pleasure!
I make recommendations for "enhanced safety" in those situations. They may or may not do it but it is in the report.
Old 8/7/06, 10:26 PM
Roy D. Cooke, Sr's Avatar
And how much protection can we give our Kids .
Do not the parents have some responsibility.
They can drink Chlorine or get the paint remover or Dads shaver in the bath room . How about 90% of the homes I do the water is to hot .
I report it and I would be surprised if ten % lower the water temperature.
I met a person I had done an inspection for and they bragged about doing none of my recommendations.
Roy Cooke Sr Royshomeinspection.com
</IMG></IMG>
Old 8/7/06, 10:37 PM
Our kids Roy protection, well as much as possible. Other kids, a couple of lines in my report usually is as far as I will go.
It' not like we are running out of kids now is it.
Old 8/7/06, 11:23 PM
jeffghooper jeffghooper is offline
Please Note: jeffghooper is a non-member guest and is in no way affiliated with InterNACHI or its members.
When you talk safety you are talking code.
If you know it could be a problem and do not note it, then someone gets hurt, and someone else knew you knew it was a problem, then you have a problem, or could have a problem. Knowledge is a powerful thing. It can also come back to bite you!
The following appears in most, if not all codes, in one form or another. You guys that keep saying you do not note code and then go on to say you state safety, or a safety concern make me scratch my head. Safety IS Code! You cannot separate them.
101.3 Intent.
The purpose of this code is to establish the minimum
requirements to safeguard the public health, safety and
general welfare
through structural strength, means of egress facilities,
stability, sanitation, adequate light and ventilation, energy
conservation, and safety to life and property from fire and
other hazards attributed to the built environment and to provide
safety to fire fighters and emergency responders during emergency
operations.
Roofing material being grandfathered dnasser Exterior Inspections 4 4/2/07 12:01 PM
A thread for serious discussion of Washington Senate bill 5778 dhelm Legislation, Licensing & Legal Issues for Inspectors 236 3/11/07 4:45 AM
