Does anyone have a good explanation of slugging as a narrative. The first time home buyers are having a tough time swallowing the fact their A/C cannot be tested.
Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
1.Due to manufacturers recommendations did not turn on the AC unit since the temperature was below 65°. Note: Running the AC when the temperature is below 65° may burn out the AC compressor unit.
You may want to verbally add that the purpose of running the AC compressor is to determine if it will cool the house properly. Since it is 25 degrees outside anyway, so run it or not you won't be able to tell anything if the house gets colder. The simple fact that the furnace is not running with do that. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I have the running the A/C below 65deg language already. I was looking for a narrative going on to say about the refrigerant not vaporizing and remaining liquid in below 65deg temps.
Never seen anything like that. TMI in my opinion, and beyond the scope. I just tell them I didn't do it and why. If they want to test it during their final walk through that's up to them, but tell them that if they do, it won't tell them anything and it may damage the unit.
Due to low outdoor ambient temperatures, the HVAC unit was not tested in the cooling mode as this is outside the scope of this inspection.
As the cooling equipment had clearly been shut down and because the weather temperature in the past 24 hours has been below 65 degrees F. I was not able to test-operate this equipment. Operating cooling system equipment which has been "shut down" without proper preparation risks costly damage to the compressor or other components Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
CYA
The home inspector is not required to:Operate cooling systems when weather conditions or other circumstances may cause equipment damage. Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
| Good info about multimeters and safety | badair | Electrical Inspections | 8 | 7/29/08 11:35 PM |
| Deere John: It's Been A Good Ride | jburkeson1 | Miscellaneous Discussion for Inspectors | 1 | 7/19/08 1:29 PM |
| OAHI Out Of Control - Bylaws Breached - Documented Proof | rwand1 | Canadian Inspectors | 175 | 2/25/08 12:23 PM |
| Grounding -V- Bonding Article (Good Read) | pdoane | Electrical Inspections | 0 | 10/12/06 5:31 PM |
