Nathan W. Swilling is a non-member guest and is in no way affiliated with InterNACHI or its members.
We're in the process of insulating and renovating an unfinished attic space in a 1915 home. Our assumption going into the project was that we would allow space for ventilation behind the insulation (under the roof) so that air could pass from the soffit vents to the ridge vent.
Well, it turns out that we actually don't have soffit vents, and we don't have a ridge vent, either. Looking up an down our street, it appears that all the homes on our street don't have soffit vents. So, the GC has suggested using closed cell or open cell foam to fully insulate the roof, and forget about ventilation altogether. Because we have a slate roof, putting in a ridge vent would be very costly. I'm not really sure if it would even be useful, because it wouldn't have anything to ventilate. This is a pretty dramatic step, so I'm looking to collect as many opinions as possible before dramatically altering our roof in this way. We live in the NE, so avoiding ice dams is an issue. |
How about opening the soffits and adding gable vents instead of ridge vents...just a thought.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Partial ventilation is better than no ventilation. T.Neyedli www.alphahomeinspections.ca |
Gable vents were my first idea, but I've heard pretty negative things about gable vents from quite a few professionals.
The slope of the roof is pretty steep, the roof is about 12 feet high and 25 feet wide. |
I have seen many unvented 100+ year old attics ,they have survived this long so as the saying goes if it ain't broke why fix it.
The slope sounds great to me to step to walk , I expect snow will not stay much. ...Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Nat,
Without knowing your location, site orientation and the specifics of your roof design, all bets are off as far as any of us really providing fact based info. He's some info from some of the most knowledgeable for general ideas on how to design your attic retrofit. Click: BS Appears some of my cohorts disagree with current technology...oh well ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 1/23/08 at 8:40 AM.. |
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I agree with Roy. If it ain't broke, don't try to fix it.
I would seal any opening in the attic floor which would allow warm/moist air into the attic area. Slate is not air tight it breathes. I would not spray foam on the underside of the roof. Bad idea.
Roof ventilation is a big issue today in the roofing industry, and it should be. Asphalt roofing shingles nailed or stapled onto plywood decks are roofs systems that will not breathe – they suffocate the roof, and proper ventilation is imperative. Otherwise the plywood will delaminate and the roof will fall apart. Slate roofs attached to board decking, on the other hand, are breathable roof systems. They are not air-tight – they’re water tight. Ventilation may be necessary to prevent condensation occurring under the roof sheathing from warm inside air leaking into the roof space. This is easily achieved with gable vents or roof vents, air spaces between the insulation and the sheathing, and ventilated soffits. However, most older residential slate roofs had no particular ventilation systems associated with them. After a century, most are still in good working order. Such is the advantage of a roof that can breathe on its own. When these older slate roofs are retrofitted with roof insulation, care must be made to ensure that warm air will not come in contact with cold roof sheathing. Aluminum ridge vents should be avoided on slate roofs. Such vents are designed to be used with asphalt shingle roofs — as such, they’re cheaply made, they do not fit the ridge of a slate roof well, and they interfere with the normal maintenance of a slate roof.
strange how different areas say different things .
http://www.google.ca/search?hl=en&q=...in+europe&meta= Added Roy http://www.buildingscience.com/docum...ented%20attics JLC has a great post on insulating roofs I will try and find it If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 Last edited by rcooke; 1/23/08 at 9:25 AM.. |
Interesting information. I definitely feel convinced that an unvented attic would be the best for my situation (Massachusetts, front gabled roof with a 12/12 pitch). Now I just need to figure out the most cost effective way of getting there.
My thought was to do a couple inches of closed cell foam, and then fill the rest of the rafter bays with spray in place cellulose. But, after talking with one insulation guy, he told me that wouldn't be much cheaper than just doing the whole thing in cc foam. I'll wait to see the actual prices. I'm a little wary I'm going to have significant sticker shock. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
