My furnace works like this: Burners come on, then blower comes on. They stay on until it makes my thermostat setting, say 74.
On some inspections, the furnace does this: the burners come on, then the blower, but after a few minutes the burners go off and the blower stays running. It continues this way until it reaches the set temp. This is on old furnaces. My question is: Is this a case of "short cycling", or on old furnaces is this the way they were designed to run? "Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
An indication of short cycling is if the burner comes on, blower comes on, the burner goes off, the blower stays on, burner comes back on again, burner goes back off again, blower keeps running. It may or may not reach set point.
The older version furnace, has a bimetal fan/limit control that heats up and turns on the blower. When the burner shuts off when the thermostat reaches set point, the blower remains on until the heat exchanger where the fans/limit control is installed, cools down. This has a "purge" affect, which is a desirable function and is incorporated even in electronically controlled blower controllers.
Mark,
There are various scenerio's for what you are describing. David gave a good explanation on (2) coun I think Equipment age, maintenance, visible condition, location, and type (ie: Gas, Electric, Ht.Pump, H.W./Steam, etc.) all play a part in the final analysis by the Pro. I think you list your observations and recommend further analysis by a Pro. |
If it has an older tstat, the anticapater may not be set causing the short cycle.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
A couple of thoughts to add.
1. This may or not be a real problem but some troubleshooting is in order. 2. The plenunm control may be misadjusted and set too low. 3. The air flow could be restricted by a clogged filter, clogged A-coil or the registers and any damperes not open alowing the plenumn temp to rise to the limit of the control. 4. The blower may not be at the cottect speed for the application by malfuction or blwoer speed setting. 4. An oversized furnace may also short cycle. |
Do you turn the T-stat all the way up, so that it should run for quite a while before the T-stat is satisfied, or do you just turn it up enough to fire the heating system? I would turn the T-stat all the way up, so the system should run for quite a while before reaching the set point (and bake the people inside so they remember the heat was working "at the time of the inspection") ... JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
All the way up...
All the above could be the cause
Number one in my book is a dirty air filter Lack of air through the heat exchanger will cause the hi temp safety to shut down the gas rlb |
So it is short cycling ? The older furnaces were not set up to run that way correct?
We just can't tell from here. Please review the following links for tips on this issue. http://toad.net/~jsmeenen/anticipator.html http://www.rd.com/content/openConten...ontentId=18229 http://www.hvacoracle.com/cgi-bin/pu...=133&s=heating http://masterplumber.net/Furnace_Questions.htm Hope this helps, good luck and be careful. Of course you could always refer to a quaified HVAC techincian for evaluation and repair as needed. |
Mark, if you turn the stat up all the way and the flame shuts off before it reaches its designated temp. I will always consider that short cycling and recommend servicing. I ususally check the filter first, try removing it and to see if that corrects the problem or not. Some of the high end filters will even restrict the air flow enough to cause this, even if they are clean.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
Thank you Darrell, very concise and to the point.
| Furnace Not Responding | vsantos | Inspecting HVAC Systems | 4 | 9/18/07 8:00 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Correct connect at Furnace | tmartens | Plumbing Inspections | 2 | 5/1/07 9:33 PM |
