For those that just operate a electric furnace from its thermostat this is not as dangerous as removing the dead front on a electric panel especially a FP panel. Looks like a mess of wiring but it is basically very simple four elements in this furnace denoted by the yellow thermal overloads. I have harped on this many times but again the only way to determine if all 4 elements are operating is to use a amp meter on each element.
OMG here comes the SOP guys Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Great, I will do this check every time.Never knew it was so simple. |
No its like painting by numbers simple yes
What happens when the amp draw is unbalanced and by how much is where I have a problem Charlie.
Great point BOB.
More of those units coming into Montreal area with energy retro fitting and Hydro Quebec being a clean source of energy. What about drop testing. Pro's, con's of stay away no need ? Dam more and more reason to buy an IR camera. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
How long does it take to do this on a furnace .
What % have a burned out element . I am an retired Electrician and no longer check elements . I found very few burned out and the times spent was not worth the effort. If a client was to call about a burned out element I missed ( Never happened yet ) I will pay to get it fixed . Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Bob mostly find 10 KW and 15 Kw heat strips a 15 kw strip pulls 20 to 21 amps every time. I don't concern myself with a unbalanced load specifically as that would generally be a loose connection with burnt wire which is very visible. I look for open circuits no amps is the most common problem. If the thermostat is cranked up several degrees to ensure the second stage heat is energized all elements should have a amp draw and they will read basically the same
Roy I have been in this business a long time and have built a very profitable business by being a perfectionist doing what others don't. You don't see me on this board whining about Lowballers whining about licensing whining about everything under the sun. I am out doing inspections not whining about crap on this MB Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Still good info even if I may or may not do this check as I see few Electrical units and they are mainly in a handful of condo units a year so far for me.
would it not be as easy to take a reading at the panel?
Yes if you knew how many elements were in use only kicker is one would not know which one was not working if the amps did not match up with the amount of elements. Plus I like to do a visual on the wiring in general inside the cabinet. More room in the furnace to get the amp meter on than most main panels just they way I prefer to do things
Hmmm,smart guy.(pick two)yeyeye.PlUcK
doesn't anybody use the lick test anymore?
| Scare Tactics for Licensing in Ontario | acavdek | Canadian Inspectors | 54 | 11/23/09 11:07 PM |
| Obama says we'll be "allowed" to keep our insurance. Allowed? Huh? | gromicko | Miscellaneous Discussion for Inspectors | 4 | 6/27/09 11:41 PM |
| Why Obama is scary... | jwilliams4 | Miscellaneous Discussion for Inspectors | 54 | 6/21/09 7:20 PM |
