Old 1/3/08, 12:01 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Draft fan & gravity vent
I know that I have run across this before and never thought about it, but yesterday I ran across 3 draft fan induced furnaces and a gravity vent water heater connected to the same flue. The flue size looked OK (was bigger at each connection). It got me thinking though, that couldn't the draft fans cause a back draft at the water heater draft diverter. I don't recall ever hearing that you cannot connect both kinds to the same flue.
Thanks
Old 1/3/08, 1:43 PM
Jeffrey R. Pope's Avatar
Default Re: Draft fan & gravity vent
Gravity vented appliances and induced-vent appliances can share the same flue system.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/3/08, 1:53 PM
mnahrgang's Avatar
Shouldn't the smallest appliance (water heater) be "above" the others? This one seems to be "after" the others, but not "above" them. I'm not arguing the point, because I don't know, but it does look like the furnaces could push their exhaust down to the water heater.
Mark Nahrgang
www.HeyMark.info
Old 1/3/08, 2:04 PM
As long as the appropriate fittings are used, and the vents are sized and sloped properly, there's not an issue.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/3/08, 2:28 PM
mnahrgang's Avatar
Jeff,
Do you know what the proper slope should be? I don't recall.
M.
Mark Nahrgang
www.HeyMark.info
Old 1/3/08, 3:46 PM
1/4 inch per foot minimum rise. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/4/08, 1:41 PM
David A. Andersen's Avatar
Did you check for back drafting?
The flue pipe must be the diameter of the largest appliance plus 50% of the other attached appliances.
I don't like the looks of galvanized gas pipe or the extension cord power supplies to the furnaces that are not protected. Or the number of unsupported fittings in the flue configuration.
Old 1/4/08, 9:19 PM
rbrady's Avatar
Every one of the furnaces also had flexible hose through the enclosure too.
I did check for any obvious back drafting at the water heater when at least two of the furnaces were running.
Thanks for the replies.
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 10:17 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
Direct vent WH with draft hood dpeterson Plumbing Inspections 9 12/30/06 4:35 PM
Gravity vent dmacy Plumbing Inspections 5 8/1/06 2:47 PM
