Old 2/22/11, 1:58 PM
David Garton's Avatar
David Garton David Garton is offline
Default Drain lines for HVAC
Yesterday I came across these drain lines. Can someone tell me what this small section of pipe with the tape on the end is for? I have not seen this before, is it some type of improper vent? I don't get it, can someone set me straight on this
Thanks
drain-lines-heating-venting-air-conditioning-p1050038.jpg   drain-lines-heating-venting-air-conditioning-p1050039.jpg
David Garton
Eagle Eye Inspection Services
david@yubacityhomeinspection.com
http://yubacityhomeinspection.com
Licensed Building Contractor
Serving Yuba City, CA. and the surrounding areas
(530) 415-1269
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/22/11, 3:28 PM
Christopher Currins's Avatar
Default Re: Drain lines for HVAC
Thanks
A clean-out, that should be capped.
Christopher Currins
Certified, Licensed
Old 2/22/11, 3:44 PM
Thanks, I new it had to be something simple I always seem to over thing things
David Garton
(530) 415-1269
Old 4/1/11, 12:44 AM
I found another one of these today and after further investigation I discovered that this is a vent and it is done right
David Garton
(530) 415-1269
Old 4/1/11, 6:29 AM
Robert Ernst Robert Ernst is online now
What is the vent for? It looks like a clean out for the trap they put in to the drain line to me and I agree it should have a cap and not tape.
Old 4/1/11, 7:03 AM
Barry Adair's Avatar
Smile Re: Drain lines for HVAC
none pictured are correct...
best practice: condensate drains should be installed at primary and secondary, trapped and anti-siphon vented downstream from the trap, advise insulating drain lines when installed in the attic or crawl
though sometimes artful the smooth wall prefab trap Chris exampled, if they'd only put the vent on the proper side, is also preferred to the cut and glue creative concoctions often encountered and unglued...
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Condensate Drainage jevans Inspecting HVAC Systems 28 11/27/10 2:55 PM
Why is this happening in america "home of the free"? gluck Miscellaneous Discussion for Inspectors 14 3/18/10 11:21 AM
Inspector in hot water after approving unit without drain rcooke Canadian Inspectors 7 2/20/08 3:59 PM
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
Plumbing drain lines should run downhill at a slope of darnold1 Plumbing Inspections 7 2/2/06 9:44 PM
