Should the dryer vent that passes through an attic be insulated in an unconditioned space? Can you see the condensation line in the insulation?
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Georgia Home Inspector (and anywhere else in North America) |
Yes, exactly for the reason you stated.
No need to insulate a dryer vent.
Is that penetrating the roof surface? If so, the shingles must be full of lint. I like to see these penetrating the soffit area.
The dryer vent is on the roof. I think the other problem is not enough attic ventilation. The only vents noted where roof vents, no gable or soffit vents.
Funny, I would write that one up as improper if I saw it used as dryer vent. Improper vent material (supposed to be smooth, not corrugated) and the termination should not have a screen. Also the vent material looks like it would require inside / out assembly (i.e., downstream piece inside rather than outside the upstream piece).
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
"M1502.2 Duct termination. Exhaust ducts shall terminate on
the outside of the building. Exhaust duct terminations shall be in accordance with the dryer manufacturer’s installation instructions. Exhaust ducts shall terminate not less than 3 feet (914 mm) in any direction from openings into buildings. Exhaust duct terminations shall be equipped with a backdraft damper. Screens shall not be installed at the duct termination." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Overheated Clothes Dryers Can Cause Fires Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
When a dryer vent terminates on the roof... I've rarely seen the required damper/backdraft protection installed.
Condensation can only occur when BTUs are removed to a point where a change of state from water vapor to liquid can occur. This will not occur when the dryer is pumping out hot air, or if stack affect (hot air rising up the pipe) is occurring in most cases. You must lower the temperature of the pipe not raise it for condensation to occur. I would venture to say that there is a negative pressure in the house and cold air from the outdoors is being back drafted down the pipe cooling it off and the improperly ventilated attic space has sufficient water vapor to cause considerable condensation. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Remember, Buck is in Kansas. Hot summers and cold winters. Betcha the condensation problem only occurs in the winter. Thus the reason to insulate the vent pipe passing through the unconditioned attic space.
Thanks! for all the information.
We have many freezing winters here in Massachusetts and insulating a vertical dryer vent (that is penetrating through the roof) is not helping matters any. As I stated above....the vent needs to be re-directed towards the soffit area under the existing insulation. |
| Dryer Vent Repair Delaware County | nhagarty | Ancillary Inspection Services & Additional Topics | 1 | 1/31/11 8:03 AM |
| Mr. Dryer Vent / Clean, Repair, Install | nhagarty | Ancillary Inspection Services & Additional Topics | 5 | 1/15/09 12:17 PM |
| Dryer Vent Repair Montgomery County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 9:22 PM |
| Dryer Vent Repair Chester County | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/12/09 9:21 PM |
| Dryer Vent Cleaning Philadelphia PA | nhagarty | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 12:24 PM |
