Old 8/18/06, 4:50 PM
Danny J. James Danny J. James is offline
Default Ducting
Can domestic water lines pass through the return air duct between the floor joist.
Old 8/18/06, 4:54 PM
Default Re: Ducting
Normally I don't see that but, if the pipe had no joints within the duct, I don't see a problem with it.
Old 8/18/06, 5:25 PM
Default Re: Ducting
Thanks Larry
Old 8/19/06, 4:18 PM
Robert J. OConnor's Avatar
Default Re: Ducting
Floor or wall return air plenums can not have gas lines or waste cleanouts, and wiring can cross the plenum but not run along the length. Plumbing pipes can either cross or run along the length of the plenum.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 8/21/06, 12:53 AM
Default Re: Ducting
Thanks Robert Connors, (you are a wise man). Let me reiterate, so I understand. A water line can go through the floor joists that is used as a return duct.
I have a customer that wants to put a water line through the air duct,so he can eliminate the water line below the return duct and finish his ceiling with dry wall.
Old 8/22/06, 12:03 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Ducting
I can think of a few reasons not to. Condensation occuring inside the return duct causing mold etc., same condensation causing the duct to rust out and copper pipes will eventually leak.
Larry
Foundation w/return air ducting through slab? lfoster Structural Inspections 8 5/21/11 9:52 AM
Return air ducting through slab? lfoster Inspecting HVAC Systems 4 7/3/06 10:54 PM
AC ducting without plastic sheathing mbutters Inspecting HVAC Systems 6 4/23/06 9:47 AM
Ducting through garage sstanczyk Inspecting HVAC Systems 2 2/9/06 11:02 AM
Question on Fresh air ducting rcross Inspecting HVAC Systems 9 1/25/06 2:25 PM
