Old 10/8/07, 10:41 AM
Charley L. Bottger's Avatar
Default Dumb & Dummer
My last two inspects were built by the same builder apparently using the same plumbing contractor as these P-traps one on the HW heater relief valve downspout and one in the attic for the A-coil primary drain were identical on both homes. I don't know what school the plumber attended but apparently it was not the same one I attended.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/8/07, 10:47 AM
Default Re: Dumb & Dummer
Had a woopsie posted wrong pic here is the hot water heater
NACHI Member
State License # 130
Old 10/8/07, 11:09 AM
W. Michael Chris's Avatar
W. Michael Chris W. Michael Chris is offline
Originally Posted by cbottger
. . . I don't know what school the plumber attended but apparently it was not the same one I attended.
He just skipped school that day . . . . . . amazing what we find every day.
Thanks for the pics.
Mike Chris, Santa Clara, Utah
NACHI: #05051385
HouseNspect@gmail.com
www.housenspect.com
activerain
"A man's home is his castle . . . until the queen arrives."
Old 10/8/07, 1:18 PM
klott's Avatar
klott klott is offline
I don't like the look's of that gas line either.
Old 10/8/07, 1:30 PM
Well tell me what you don't like about it.
NACHI Member
State License # 130
Old 10/8/07, 1:40 PM
Patrick J. Cloninger's Avatar
Patrick J. Cloninger Patrick J. Cloninger is offline
From the looks of purple primer they are probably not professional plumbers. I can't speak for everywhere, but here purple primer is not used by most plumbers (it is usually clear).
I might be missing something about the gas line. What is wrong? Always looking to learn something.
</IMG>
Serving Knoxville and surrounding counties
Old 10/8/07, 2:33 PM
Doug Edwards's Avatar
Most plumbers here use the purple "cleaner/primer" for that very reason; that it can be seen and verified by the code inspectors. Too many had the inspectors question whether or not they had in fact used the cleaner/primer prior to glueing up the joints. Creates less problems for plumbers in the long run. Guess it depends on the relationship between the area's contractors and code guys. Good point to bring out.
- John Stuart Mill
Old 10/8/07, 5:34 PM
</IMG>
Pinpoint Home Inspections
www.pinpointtn.com
Pat you will have to ask Ken I had no problem it went from point A to point B and had no kinks
NACHI Member
State License # 130
Old 10/8/07, 7:20 PM
Charley,
Did you ever find a drip-leg in the gas line for the WH? I didn't see one. Maybe the installer kinked/trapped the flex thinking that would replace a drip-leg.
HUH?
Old 10/8/07, 8:09 PM
Originally Posted by gveal
Charley,
HUH?
Greg
Local AHJ does not require a drip leg in any space that is not conditioned. Garage, Attic, or outside due to the possibility of freezing. The chances of a drip leg freezing in a closet of the garage is nill. I don't get in a Pi**ing contest with the plumbers over that just as long as there is a manual shut off valve at the appliance.
NACHI Member
State License # 130
IR: Giving it away for free... DUMB kshepard Miscellaneous Discussion for Inspectors 105 11/4/07 4:00 PM
Dumb Waiter gets a citation violation mcyr Electrical Inspections 4 8/18/07 9:58 AM
Probably a dumb question ltreesh Inspecting HVAC Systems 8 6/14/06 12:46 PM
