Old 10/13/10, 12:45 PM
chiatt chiatt is offline
Default Eco2000 ground source heat pump
Okay, never posted before, so hope it is correct!!! Have an inspection next week with Eco2000 ground source heat pump and need to know how to inpect this equipment. Pictures and /or explanations would be sooo helpful. I have been researching function on internet and somewhat understand, but don't know how to operate and inspect.
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/13/10, 12:47 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Eco2000 ground source heat pump
Hi Cathay,
Welcome to the board.
Please go into the control panel and add your location. It will help us answer your questions.
Thanks,
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 10/13/10, 12:50 PM
David P. Valley's Avatar
Originally Posted by gbell View Post
Hi Cathay,
Thanks,
What's the difference? A heat pump is a heat pump....
Cathay,
I'm not sure about the Eco200 bu a typical heat pump inspection is explained here..... http://www.nachi.org/forum/f20/heat-pump-19668/
Old 10/13/10, 12:53 PM
James H. Bushart's Avatar
The SOP should help you. Stick to it, and you can't go wrong.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/13/10, 1:18 PM
I guess what I am asking is if I need to do anything special if it is using hydro as heat source and is there a way to tell visually if it is vertical bored or horizontal loop without being present at construction.
Old 10/13/10, 1:25 PM
All you are reporting on is whether or not it produces heat with the normal operation of the controls and, perhaps its age, size and manufacturer. Suggest to your client that they contact the AHJ for copies of permits and inspections to determine how it was built.
Never report what you cannot see.
James H. Bushart
314-803-2167
Old 10/13/10, 1:31 PM
Matt Berman, CMI Matt Berman, CMI is offline
Wink Re: Eco2000 ground source heat pump
Ditto what James say's
Old 10/13/10, 1:33 PM
Thank you James
Old 10/13/10, 2:36 PM
Michael R. Boyett's Avatar
http://www.nachi.org/forum/f2/geo-th...=ground+source
Old 10/13/10, 2:41 PM
Thank you James
You're welcome.
Others may not agree, but you stand to gain nothing and lose a whole lot if you use your inspection reports as a tool to impress others with your "knowledge".
James H. Bushart
314-803-2167
Old 10/13/10, 6:24 PM
Don't want to impress anyone other than myself!!! Just like to understand what it is I am looking at. Thanks again.
Cathay Hiatt
TasMar Inspections
(816) 260-1903
inspect.myhome@yahoo.com
Adapt and Overcome
It is true of the nation, as of the individual, that the greatest doer must also be a great dreamer.”
—Theodore Roosevelt
Old 10/13/10, 7:26 PM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
Originally Posted by jbushart View Post
You're welcome.
THANK YOU! I agree completely.
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 10/13/10, 9:23 PM
David A. Andersen's Avatar
Cathay,
Sorry, but that is not true.
Other than they both reverse refrigerant flow between heat and cooling, they are a different animal.
Cathay,
Turn it on, see if it makes heat or cooling in the appropriate season. Look for water leaks and you never want to see frost or ice anywhere.
Anything more than this is way outside the scope of a home inspection.
BPI# 5015804
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 8:19 AM
Heat Pump questions psiposs Inspecting HVAC Systems 4 4/11/07 3:17 PM
Carrier heat pump fires? lprinzi Inspecting HVAC Systems 3 10/12/06 7:31 PM
