Would you recommend an elbow be installed on this HE furnace exhaust. It is located under the deck. Sliding glass door to deck is directly above.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
is the moisture on the deck boards caused by the exhaust vent ?
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
How would you know if it is raining?
It was not raining. No snow on top of deck either.
I would "recommend" an elbow, due to the moisture, and the heat from the exhaust may create an issue over time.
agreed needs to be away from wood if it's causing moisture problems
You need more than an elbow if the door is above.
The exhaust should not terminate under the deck
Nor under the door.
rsummers is a non-member guest and is in no way affiliated with InterNACHI or its members.
This vent should be extended out five to six feet from operable doors or windows depending where you are at. But it should be ran out so its not creating any moisture issues on deck framing.
A vent shall not terminate
(a) directly above a paved sidewalk or paved driveway that is located between two single-family dwellings and serves both dwellings; .................... (h) underneath a veranda, porch, or deck unless (i) the veranda, porch, or deck is fully open on a minimum of two sides beneath the floor; and (ii) the distance between the top of the vent termination and the underside of the veranda, porch, or deck is greater than 1 ft (300 mm). Check your local requirements. |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Is this type of elbow OK for "buried" use? | mthomas2 | Electrical Inspections | 37 | 1/2/07 3:31 AM |
| Nails in carport roof | pelforth | Exterior Inspections | 4 | 7/16/06 8:14 PM |
