Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
When I come across a heat pump air handler, the label on it is never marked as to which heating element is installed, thus not able to correctly identify if the associated breaker is of the correct amperage and not overamped. Are there other ways to determine this?
A heat pumps primary source of heat is the reverse cycle of the freon and will just require the outside condensing unit and the indoor blower fan section to be operating. If an electrical furnace is used as the secondary source of heat the name plate data will normally tell the KW of the electrical heat strips and its breaker would be rated for the amount of strips installed within the furnace. That probally is as clear as MUD. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/23/07 at 5:41 PM.. |
Charley,
Dang I hate to admit that Oklahoma may be more advanced than Texas, well at least just this once |
I know how heat pumps work, but my question is how do you tell if the aux. heat strips are installed in that particular unit and if so, which one which depending if they are or not, would dictate the max. amps of the circuit breaker.
Andrew,
Exactly. |
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lets start this over You can not tell how many strips are in a furnace by looking at the name plate this is a correct statement. You have to remove the front cover and actually observe the amount of strips present. I have stated this many times and other HVAC guys disagree that an HI should do this but I use a amp meter on the individual strips to determine if they are working or not. These furnaces use a sequencer switch to time the strips on so they do not all come on at the same time. The breaker size is going to be determined by the amount of strips in use for the particular furnace. Just looking at the breaker size will tell you nothing. So basically there is no hard fast rule to go by If I observed a 30 amp or a 40 amp double pole breaker on a furnace I am going to see how many strips are in use. Most furnaces that I see normally have at least a 60 amp breaker in use. If you have two strips pulling 25 amps per strip common sense should dictate the size. Again this can only be determined with an amp meter. Other than that you are just shooting in the dark. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Understood. Thanks for the info. It would be nice if the installers of these units would take an extra 2 seconds and check off which element is installed so we can make sure the unit is not overamped at the breaker.
That was quick! Another quickie... Take the cover off the air handler and look inside. Most heat banks are labeled and you can count them. |
</IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 11:46 AM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Electric Hot Water Heat | gmathias | Inspecting HVAC Systems | 21 | 11/6/07 7:27 PM |
| Infloor Electric Heat | gwilcox | Electrical Inspections | 5 | 4/17/07 12:55 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 6/1/06 12:21 AM |
