Electric air handler installed in attic for cooling only (boiler heat). The breakers/disconnects on the unit were 60 amp. The wiring supplying the unit was only 14 ga. on 15 amp fuses. System about 6 yrs. old.
Can someone enlighten me on this one? |
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
Anyone????????
Did you happen to get the data plate info?
As in what? Serial #????
I was mainly wondering about the size of wire for the 60 amp breakers on the unit. When, I got to thinking about it, wouldn't the air handler just have to have enough power for the blower, hence the 15 amp/14 ga. wire? I know it's not the greatest, but here's a pic. |
The data plate will often give the minimum and maximum circuit capacity.
There's no hazard here, the conductors are sized appropriately for the 15 amp breaker, but I can't offer any ideas as to why the disconnect is 60 amps. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
The airhandler is setup for optional installation of electric heat strips, 10kw typical.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Electrical Safety Media Center | jtedesco1 | Electrical Inspections | 1 | 3/15/08 9:18 AM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
