thance is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why would air be coming out of the cool air return in an electric forced air furnace? Thanks.
Are you finding this with the system on or off?
If it has air coming out the return when running then the fan is running backwards or has the wrong type squirrel cage atached. If it has air coming out when off then you have a duct leak. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
System is turned on, and cool air is coming out of the return. It feels like a fan.
Probably either squirrel cage has been replaced and installed backwards and/or motor is running backwards and/or squrriel cage is original and blades are missing and/or free-wheeling allowing the cavitation of air, giving the effect on reduced airflow and/or moderate flow back through the return system. I've seen all of the above , in seperate situations, but all are possible and probably other conditions I/ve never seen or heard about. A Pro HVAC Tech. should be able to figure it out though.
Squirrel cage blowers running backwards still blow in the right direction, just not enough.
There is not enough information to determine anything from here. I still say there is something detached in there. |
First is it a squirrel cage?
Is there more than one source of "return air" More information is needed --- Here is a real simple answer If the fan is close to the return air and is trying to move more air than the system will handle some air will be forced out a close by return as an eddy current ---- In short more information needed - This might be normal for this system rlb |
You guys are whizzing against the wind here, to many variables could be any of a dozen reasons the unit needs more than just a visual look from the exterior.
</IMG></IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Electrical Safety Media Center | jtedesco1 | Electrical Inspections | 1 | 3/15/08 8:18 AM |
| Vent for Electric Furnace?? | mlong | Inspecting HVAC Systems | 6 | 11/7/07 9:16 AM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 8:00 PM |
