Old 4/4/07, 3:31 PM
Skip Erwin Skip Erwin is offline
Please Note: Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Emergency Air Handler Shutoff
I came across this today. Sorry for the bad picture. Obviously its purpose is to shut off the air handler in an emergency. It's in a Townhome that's a business on the first level and residential on levels two and three. All three levels are serviced by one HVAC system. Is it so that the fire department doesn't have to look for the thermostat? What are the primary concerns? Is it an issue with gases on the first floor being spread to the upper levels? Or could they be worried about gases inside somehow being exhausted outside?
Old 4/4/07, 6:00 PM
Default Re: Emergency Air Handler Shutoff
Skip
For the most part the design (as bad as it is, in MY opinion) is to shut down the airflow to minimize fanning the flames, in case of fire, on any floor.
I assume there is some sort of automatic volume damper (VAV), incorporated with a fire rated damper (FD-type B?) for each floor/zone. It's dumb, especially in a Comm./Res. mixed use setting.
Old 4/20/07, 9:23 PM
bbenjamin bbenjamin is offline
Please Note: bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
In some states this is a DHEC regulation for such applications as Day Cares and Nursing Homes. They should be used in accordance and along with duct smoke detectors which if use correctly will prevent the spread of smoke through the duct system. Sprinklers are also a part of this regulation.
Emergency heat dmacy Inspecting HVAC Systems 5 11/21/07 12:11 AM
Private plumbing main shutoff location jburk2 Plumbing Inspections 9 8/19/06 5:23 PM
Emergency Room jferry Miscellaneous Discussion for Inspectors 16 6/19/06 8:28 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 11:06 AM
Shutoff Valves?? tpriddy Plumbing Inspections 9 2/23/06 5:57 PM
