What is the proper temperature when running the emergency heat.
I was only getting about 70 degree air. The heat pump was working properly in the heating mode. |
the temp of the air being produced by the emmergency heat will depend on the ambient air temp, what was the inside air temp or the difference between the supply and return. Also it is not unusual to find one or more of the heat strips have burned out. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
That temp of 70F output at vents is low for the emergency heat mode. As Gerry suggests the electrical elements could be burned out or a relay?
How long did you run the system in the emergency heat mode?
Time for a good HVAC man to check it out
You have done your job to say that it does not smell right rlb |
For a two stage system, heat pump and aux heat back up, the selector switch (heat/emergency heat) only tells the system which one is the primary. In the normal 'heat' mode the outside temp dictates which is the primary heat source, and regardless of what heat mode, both are controlled by the thermostat.
Get some chat time with your local HVAC dude, as quick call like a consumer can get a wealth of info. tom |
| efficiency of 15 yr old peerless | afrost | Inspecting HVAC Systems | 11 | 11/19/07 10:51 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 6/1/06 12:21 AM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Heat Pump Check list for inspecting | dmacy | Inspecting HVAC Systems | 21 | 2/1/06 1:56 PM |
