Is this enough combustion air for a water heater and furnace?
Thanks! for your input. |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
Absolutely not.
Write it up. At a minimum....a louvered door is recommended. |
Thanks! David,
I did just that. Funny thing it was built that way 11 years ago. |
Combustion air calculating.
http://www.achrnews.com/CDA/Articles...00000000239415 Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
sure it is if you don't want to light the hot water tank or use the furnace...now if you want to use either of those things you need to remove that door or provide a louver door as the minimum acceptable amount of ventilation...imho....jim
http://www.houseofcraig.net/combustion_air_calc.html InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
It would appear to be an inadequate C/A design.
Knowing the capacities of the Furnace & Water Heater will help in sizing of the openings, but just as important is the location of the openings. You should always have adequate openings in a high & low design, preferably opposite walls or corners. IMO |
Was it direct vent by chance? If so, it get's its air from outdoors.
I don't see how anyone can answer the question from the picture without knowing the type of furnace and water heater (source of combustion air), the total BTUs for them, and the cube of the room behind the door. What if that room leads to a large utility room? Let's not assume it is just a closet.
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
The question was if this sole supply of air is enough for the mentioned applications and it isn't. The question did not refer to any other source of air supply.
Are those mechanicals (in that closet) high efficiency? |
maybe they are electric
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Even if combustion air is from the vent on the wall, then combustion air will also come from the room/closet . You can not assume by only seeing a door that the room or closet is not large enough to support the furnace and water heater. There was no mention of a closet or room in the initial question. Can anyone tell what is behind a closed door by seeing a door? I don't think it is wise to assume things when inspecting.
We simply were not given enough information to make any reasonable determination. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
There were not high efficiency or electric. I could not found another source of combustion air. Homeowner had recently finished the basement.
| Combustion Air | hmcbride | Inspecting HVAC Systems | 18 | 10/25/08 6:27 AM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
| Combustion Air Availability? | cradan | Inspecting HVAC Systems | 4 | 2/19/06 9:16 AM |
