Does anyone know the requirement for California....does it have to be concrete or can it be an equipment pad made out of some kind of fiber / poly?
I ask because I see alot of them around here especially on newer construction. Thank you for your help ahead of time. |
| Find an InterNACHI certified Wyoming Home Inspector (and anywhere else in North America) |
New construction down here is that fiber/plastic stuff. Didn't know there actually was a requirement as far as type of construction material, only that it should be raised off the ground.
BUMP
The fiber/plastic stuff is all I see (if there is a pad). Sometimes the units are elevated off the ground and supported by metal beams coming out of the foundation. As far as I know, as long as it's not on the ground (or sitting on a rotten piece of plywood) it should be okay.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 6:46 AM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
