OK, this is the first time I have seen this setup. Owner installed Evaporative cooler in garage. Cut hole between garage and kitchen so that the air blows into kitchen, etc....I noticed a gap in the top of the garage door and he indicated that is how the evap unit gets the fresh air. You will notice that on the top hinge it indicates summer and winter so that in the winter they move the top hinges so that the garage door will not have a space at the top. This was a townhome and he said the HOA said they had no problem with the evap unit in garage and they suggested the garage door setup. How would you write this on the report, substand install, etc....
Thanks Charley. This was my concern as well was the return air.
Oh yea, I already had mentioned that to them right off the bat.
Man, the Harry Homeowner HVAC company is everywhere!!!
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Keith McKinley is a non-member guest and is in no way affiliated with InterNACHI or its members.
how is the air returning into the home from the garage? This is just a condensor.There is no air flow into the home.
Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| Installing GFCI in garage with no ground | cyezza | Electrical Inspections | 53 | 11/30/07 5:05 PM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior Inspections | 33 | 3/17/07 7:28 PM |
| Garage fire rated wall | jlybolt | Interior Inspections | 3 | 6/18/06 6:21 PM |
| Garage Firewall | jfunderburk | Structural Inspections | 19 | 4/9/06 7:23 PM |
