Old 7/18/07, 2:47 PM
lfoster's Avatar
lfoster lfoster is offline
Question Evaporator drain line
Looked at a house that had an electrical, split system with the evaporator in the attic. The emergency drain was visible in the front gable, but I did not locate the primary drain.
There was not a primary drain on the exterior wall, and no drains tapped into the sink / basin drains.
Can the evaporator be drained into piping in the attic?
Needs a P-trap?
Thanks,
Old 7/18/07, 3:11 PM
Christopher Currins's Avatar
Default Re: Evaporator drain line
condensate traps
Scott Schultz
Here is a thread that may help.
Christopher Currins
Certified, Licensed
Charley L. Bottger's Avatar
Needs a P-trap?
Thanks,
Nope can not connect to attic vent even with P-trap unless it is a high efficiency furnace and you stated it was electric so that ends that.
Should be able to follow the drains from the A-coil even if they are buried in insulation. My guess is the primary drain is connected somewhere to a plumbing vent and is not allowed.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 7/18/07, 8:35 PM
lfoster's Avatar
Thanks, you confirmed my thoughts.
Linda
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
Gas line protection jlybolt Exterior Inspections 2 5/30/07 12:18 PM
Water line repair program. dmacy Plumbing Inspections 2 1/10/07 10:22 AM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
