I've seen exhaust pipes like this (in the winter) with ice on the exterior. I believe this is a home-made job to keep the moisture from getting that far.
Does any one have any ideas of what causes this? Thank you. Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Two thoughts one being you live up there with Santa Clause it appears some one has excessive moisture traveling back down the exhaust flue either from condensate in the winter or if there is no 180 degree fitting on the exterior side rainwater could be entering the pipe in any event someone is draining the system before it gets inside the furnace cabinet for what reason I know not
I'd like to know where that drain tube "drains to". Seems to me it is high risk for CO being reintroduced into the home.
The tube has a trap
I'd bet you 'dollars to doughnuts' come wintertime in Wisconsin, that trap don't perform as well as it should, and it goes dry. Then what? Hope there's a CO detector nearby to wherever it terminates.
JMHO, and I'm entitled to it! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
For draining flue gas condensation on a HE unit. Looks site made, which might be OK depending on mfr instructions. The loop is intentional (as Charlie indicates it is a trap). Pay attention to where it drains as the water will be corrosive due to combustion byproducts.
I usually see them tapped off of a concentric vent. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
So basically you are endorsing this, and have no concerns what-so-ever? Just trying to understand and learn (I ain't too old yet). Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
As for a health concern IMHO no CO would get past the loop trap but yes it is a Piss poor way of getting from point A to Point B if properly installed the flue pipe is designed to slant back toward the factory drain hoses within the furnace cabinet and with a 180 degree exterior fitting there should be no rain water to deal with Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
That tube connects with the normal condensate tube coming off of the furnace.
My guess is the Wye fitting and the hose is used to compensate for rain water because the contractor did not choose to use a 180 degree fitting on the exterior. Hot flue gases rise I don't see them making a 90 degree turn into the hose connection even if the hose trap was dry Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| Single wall exhaust pipe | nrichards | Plumbing Inspections | 3 | 4/15/09 8:09 PM |
| Radon Exhaust Noise Neighbor | Brian Sampson | Ancillary Inspection Services & Additional Topics | 1 | 4/12/09 9:52 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Excessive AC Condensation Problem | kweiss | Inspecting HVAC Systems | 8 | 8/6/07 9:15 AM |
| Insulation around Exhaust Pipe | rchewning | Plumbing Inspections | 4 | 6/18/06 9:01 AM |
