Greetings...I have seen on numerous peeks in the furnace area that exhaust and intake pipes are being enlarged. Referring specifically to exhaust the ITA manual notes as a no no both reducing (understandable) and enlarging the pipe. I talked to a furnace expert who said that is just done when there is a 'longer run'....I see in this case the exhaust (I'm presuming) is reduced back down. Looking for input from a wide array of experts inspectors who have probably seen this many times also.
and by the way....thanks for that! mike in MN |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Usually see a T fitting being used to terminate the exhaust flue. Serves as a rain cap.
Guess the installer forgot it and didn't wanna run back down to his truck. http://www.inspectorturley.com 1(847)494-3319 "You must learn from the mistakes of others. You can't possibly live long enough to make them all yourself." - Sam Levenson |
I don't see anything "enlarged".
my rhetoric may be flawed. I simply mean the vent connector pipe is enlarged. silly me I did not take a pic at the furnace only on the roof. However here is the page out of kaplan systems and standards which basically pronounces anathema both reducing and enlarging vent connector but has the exception where more then one appliance is vented. I did not see that to be the case....and the reducer at the top end caused me to try to concoct theories....too much space to pressurize with forced draft? maybe the reducer has a venturi speed up effect Surely others have seen similar.
mike in MN where the ice just went off the lake |
Quoting "Kaplan" will not get you too far in this business. Find the local building standard for the area in which the home is located and refer to it as your reference. A defect is not a defect simply because it doesn't meet the "Kaplan" standard. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 4/28/11 at 6:03 PM.. |
ok thanks you all....looks like what i can glean from this situation is 'everything is reletive'...just like back in college philosophy, but seriously yes, good input (checking local standards and unit specific instructions) will be heeded. however my furnace guy did say its just 'when the run is too far' Kaplan of course does not claim to be absolute authority on everything and they always advise to be aware of local standards and codes which would trump the general guidelines they are teaching. so I have lots of good advice....was just looking to connect with others who may have had the same questions.
thanks from mike in MN |
Why do we need a "rain cap"?
Anyone know? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Because the draft inducer impeller will be in water during the non heating season and eventually rust and die.
If the reduction is too small on a 90% or greater furnace, it will shut itself down in a few minutes.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Are you sure??????
Absolutely unless a drain is drain fitting is provided.
HMMMM you never mentioned a drain line! just asking Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Charley, do I have to tell you everything?
The condensation is supposed to flow back to the furnace. There is a drain designed to take care of this stuff. A little rain won't matter. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Popular home inspection text book now referencing NACHI's SOP and COE. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 7/1/07 1:51 PM |
| NACHI and Thomson Education Direct collaborating on an inspection text book. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 2/4/07 8:47 PM |
| Mildew in hallway | Steven Brewster | Ancillary Inspection Services & Additional Topics | 18 | 1/12/06 1:03 AM |
