Split system Tag states heat pump but unit has no compressor or reversing valve at the exterior unit
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Maybe this will help note the two lines 7/8 copper into the box this is not a ground source heat pump no water
radiant heat (coolant) 7/8 copper would lead me to believe source coolant from closed loop? am I close? I can't see 2 lines at the pump outside.
No closed loop no outside pump strictly air to air. The system has a conventional thermostat and when placed in the cooling mode the unit produces cold air at the registers. The kicker is if you touch the large line at the exterior unit it will burn your hand. The key word is in the cooling mode
Ok i'll try again it it a split system duel fuel ductless heat pump?
The compressor is within the box in the attic hot gas line travels to outside condensing unit liquid line from exterior unit back to the attic A-coil. This system originally had a electric furnace but has been converted to Natural gas. The reversing valve located in the box with the compressor is no longer in use thus the conventional thermostat. This system operates as any split system does except the compressor is remote from the outside unit. Very miss leading just reading the label on the unit because it in essence it is no longer a heat pump Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
how can it be a heat pump without compressor? hence this question. Where is all the ducting? and is that an erv in the backround?
and why 7/8 copper? thats huge isn't it? I was even on the carrier site trying to figure it out. Last edited by dhuxted; 10/26/10 at 11:10 AM.. |
Its a carrier 38 series air to air heat pump and should be coupled with either an air handlier with electric heat or a gas furnace. The outdoor unit is just a condensing coil, the compressor, reversing valve, etc are located in the heat pump section (the enclosed box in your 2nd pic). Were very big sellers in their day but prone to service issues due to age.
It was originally a heat pump but when they installed the gas furnace they disabled the reversing valve except for cooling
Very interesting.
Does the interior located compressor produce excessive noise? How do they cool the compressor/motor inside the house, is it inside the duct/air handler with the evaporator coil or a separate unit? What gauge wire/amperage goes to the condensing coil unit? I would think that it could add to the cost of conversion if it was undersized for a conventional condenser/compressor. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
The supply wiring was sized for condenser fan only and would have to be upsized for conventional A/C unit if updated not a big problem Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it's like one I worked on one time just like it that had been converted from the old "indoor compressor" type heat pump;
The compressor is cooled the same as all split system units which is by the cool refrigerant gas returning via one of the 7/8" o.d. lines which is the suction line coming from the evaporator. |
| Inspection Agreement Review. | bsavage | General Inspection Discussion | 21 | 5/11/08 9:20 PM |
| Clueless Client? | jpassailaigue | Plumbing Inspections | 5 | 8/2/07 3:35 PM |
| ILLINOIS Section 1410.200 Standards of Practice | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 11 | 3/9/06 11:22 AM |
