Does anyone know about clearances on exterior A/C units?
I have a home that has two exterior A/C units only 6 inches apart. They are also under 12 inches from the home, resulting in poor air flow. Home owner says this is a non-issue, since his brother installed the units (you know how this is). I have another home that has an exterior A/C right in front of the 200 amp meter. Specs? Thx. CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle Last edited by gfarnsworth; 10/5/11 at 3:32 PM.. |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
1-3 feet on at least 3 sides and 4-6 feet above (depending on manufacturer).
Recommend you obtain manufacturer docs to confirm. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
12" from house 24" from each other.
Depending on service panel accessibility. 200 amp meter requires 30 x 36" clearance, does it not? Others may come up with different Mfg crap, but I have field tested and observed these clearances are required to prevent changes in equipment performance in the state of Tn. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Just looking for documentation for a disgruntled home owner.
CMI means that I do detailed reports, long in length, charge higher fees than any other inspector, alarm the home buyers of any defects, have a high rate of killing any deal, and are starving at the moment due to lack of business and competitors charging $199 to $249. CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle Last edited by gfarnsworth; 10/5/11 at 5:44 PM.. |
I'm sure the installation manual provided a clearance diagram but we don't have access to the model or mfg.
Do you? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
2004 Trane units. I will check online. Thx.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
| Vent clearances around exterior AC condenser | jfrederick | Inspecting HVAC Systems | 3 | 8/15/09 5:55 PM |
| HVAC condenser clearances | cfolsom | Inspecting HVAC Systems | 7 | 11/22/07 3:03 PM |
| Reference for clearances | dmacy | General Inspection Discussion | 6 | 11/8/07 10:58 AM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
