Josh Friedman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hello everyone,
I got the unfortunate news yesterday that the inducer motor on my 2002 Carrier gas furnace has failed (Series 100 58DLA090-10114). Given the price for the repair job, I have decided to attempt to replace the motor myself. I was quoted $900 to replace the motor. I found the part (Carrier part number HC21ZE122A) online for $70 plus next day air shipping. I'm pretty mechanically savvy but don't have much experience with HVAC systems. I was hoping for some advice on this job. Has anyone done this job before? How hard? Any good resources to guide me through it? Pitfalls? If anyone has replaced an inducer motor on a similar model and could provide me with some guidance, I would really appreciated it. Josh |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Take the housing bolts out of the frame pull the blower out of the housing take the blower wheel off and install it on the new motor replace the same takes about 10 minutes Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
So it really is as simple as:
1. Cut power source 2. Unbolt current motor and fan and remove wiring 3. Replace current motor with new motor 4. Rebolt assembly and reconnect wiring ?? Thanks for your response. |
Seeing as the unit is 10 years old I would make sure you have a new blower wheel to go with that motor.
It will take you longer to take off the blower will then install the entire assembly. Corrosive gas takes its toll on those things. Red ( hi temp) RTV goop is good to have handy (if it doesn't come with the motor). If you have a "pressure proving switch" you don't want any leakage from the blower assembly or it may affect the firing sequence. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I recently pulled mine and took it apart to clean everything. From start to finish it took about 30 mins. but it was hotter than the hinges to hell outside and I had to take a beer break. I went ahead and changed the capacitor while I had it apart as those only cost a couple bucks at the wholesale house. Just make sure you line up the blower wheel so it does not rub against the fan assembly. Basically just a motor swap and about a simple as it gets.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Thanks to everyone for their advice. I should receive the part tomorrow and will let you guys know how it goes. Hopefully no kinks along the way.
Doug, I think you worked on your blower, not the induced draft?
No caps on a motor that small... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
You are right, that is exactly what I did. Thanks for clearing that up.
So, for anyone I confused....Never mind! "War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 10/4/11 at 9:20 PM.. |
| Inspector Failed to Detect Mold | dplummer | IAC2 Indoor Air Forum | 0 | 5/18/09 7:14 PM |
| Consumer Advocacy Group Announces Opposition to Missouri HB 2057!!! | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 37 | 3/14/08 10:14 PM |
| TWO failed compression couplings | Walt Wys | Plumbing Inspections | 9 | 2/26/08 7:02 PM |
